First post, by rain
- Member
hey, is it possible to use voodoo graphics (voodoo 1 ) on pcem ? there is no option on settings menu only vooodoo 3's and banshee. i want use it with 98se. thanks.
Look carefully, it's there.
feda wrote on 2025-09-13, 05:55:Look carefully, it's there.
yea i see it on menu but its not working with when only selected vodooo 1. which gpu to use with it ?
Voodoo (and Voodoo 2) are just 3D accelerators. You have to use a regular video card in the system. Just select the Trio64.
jh80 wrote on 2025-09-13, 10:29:Voodoo (and Voodoo 2) are just 3D accelerators. You have to use a regular video card in the system. Just select the Trio64.
ok i done that but in device manager there is only Trio64 card and not vodooo1 card. how to set up drivers for vooodoo 1 ? thanks.
If you're in Windows, then you have to install the appropriate 3dfx drivers: https://3dfxarchive.com/3dfx.htm
jh80 wrote on 2025-09-13, 12:04:If you're in Windows, then you have to install the appropriate 3dfx drivers: https://3dfxarchive.com/3dfx.htm
I have Voodoo installation videos in my channel (Diamond drivers).. 😃
Some quick info:
Direct3D support in early Voodoos isn't best, it's more of an afterthought. Glide has priority.
It's like with S3 ViRGE maybe, which works better with its own API too (S3D).
Direct3D v5 is the max. for both cards, I think.
It highly depends on the drivers.
Thanks for answers .
Is pcem or 86box performs better than real hardware ? Always think about that.
rain wrote on 2025-09-15, 00:21:Thanks for answers .
PCEM does a better job at some things I think then x86box. I have better luck with audio working correctly for windows 98 and performance using pcem, but that is just my personal experience. I actually have a machine at home that is what I like to think as the bog standard windows 98 machine.. Voodoo3 2000, sound blaster live card, slot 1 233mhz CPU using intel chip-set. Running that machine and PCEM at the same time I cant really tell much difference in performance other then my real hardware machine seams to be less jittery sometimes. But if you have a good PC then you can get pretty good performance out of the emulator.
Its definitely cheaper alternative then building out a rig these days. Old hardware has really jumped up in pricing esp as less and less of it is floating around.
Yeah, you can run Voodoo 1 in PCem, but it’s a bit hidden. PCem doesn’t list it in the main video menu like the 3 or Banshee. You need to pick a motherboard/ISA setup that actually supports 3Dfx cards and then manually select “3Dfx Voodoo Graphics” in the video options for that ISA slot. Works fine with 98SE once set up, just remember to install the right Glide drivers inside the VM.
