renejr902 wrote on 2025-09-14, 04:28:
XT was popular. 8086 rare. i got a 8086 2 years after the 8088, with 640k too and cga.
Well, yes and no. Depends on point of view.
PC and PC/XT clones did follow (the somewhat modest) IBM design closely.
However, serious developers had used the real thing, the 8086.
The STS, the Space Shuttle had used 8086s, for example. ;)
The c't-86 homebrew PC from 1984 used Europa-card boards and an 8086.
S-100 computer cabinets used 8086 cards rather than 8088, I assume.:
The i8080, i8085 and Z80 all were full versions, but the i8088 was cut-down.
http://www.s100computers.com/Hardware%20Index%20Page.htm
The Olivetti M24 (aka AT&T 6300, LogAbax Persona 1600, Xerox 6060) had 8086. And 400 line CGA.
Europe's shortlived bestsellers PC1512 and PC1640 used 8086. Also had enhanced CGA.
Or the Victor Vicki portable of 1984.. Also an 8086, running at 4,77/7,16 MHz.
The problem is that many early 808x computers running DOS had some level of IBM PC compatibility (such as CGA, BIOS interrupts or floppy controller),
but were not IBM PC clones (aka "IBM PC or compatible", "IBM compatible" etc).
They belong in a separate category, the so-called "MS-DOS compatibles".
Because it was Microsoft who licensed DOS to other manufacturers (OEMs).
The DEC Rainbow 100 or Sanyo MBC-550 can be considered examples, maybe.
I really don’t mean to annoy people or try to nitpick.
It's just that the era of CP/M computers running DOS is hardly remembered anymore.
Before the IBM PC became industry standard, it was common to adapt OSes such as CP/M for a specific computer model.
Applications such as WordStar merely needed to be told which terminal type to be used.
For example, VT-52 or VT-100 were simple serial terminals, but with cursor control (via escape sequences).
Edit: Here in Europe, as far as I understand, the IBM PC wasn't available in 1981.
Well, except in low numbers, maybe. IBM wasn't sure about international sale.
Hence it took up until 1983 that the IBM PC was available (in UK first?).
So over here in Europe, it was the Sirius-1 which almost became industry standard/market leader - rather than IBM PC.
Edit: About RAM.. Let's put it this way:
The minimum -in early 80s- to run DOS 2.x reasonably was 256 KB. So that’s our lower bottom.
Many low-end PCs of 1983/1984 did have at least this. 512 KB was being the recommended, though.
By 1985, the full 640 KB wasn't being uncommon.
Applications ran out of memory already, hence the birth of EMS.
Computers with 256 KB of RAM or less either ran IBM's ROM BASIC or MS-DOS 1.25.
Which almost no applications from 1985 onwards do support anymore.
The famous Norton Commander needs MS-DOS 2.x already, for the directory support alone.
Computers stuck to MS-DOS 1.25 often are the MS-DOS compatibles who were abandoned and didn't receive any updates anymore.
Though in some cases, some still got their final boot floppies with MS-DOS 2.x or 3.20 (!).
Edit: My recommendation is to get an cheap 8088 laptop, such as Toshiba T-1000, for testing purposes.
It usually has CGA, no HDD (but RAM disk or second FD drive), runs MS-DOS 2.11 from ROM..
The on-board RAM has 512 KB, as well. Being a laptop, its years behind the current gen and compares to an early desktop PC.
