First post, by Nicolas 2000
I already have a killer W98 retro PC which covers everything up to DirectX 7. The hardware can run many DX8 and some DX9 games, but the PC performs better under DX7 so that's the limit. On the other end of the spectrum it runs quite a lot of DOS games, but I might add a "maximum compatible" DOS PC eventually.
But now for everything retro above DX7. These are my current DX8/9 retro games:
For truly recent games I have a fat W11 i9 laptop; so this XP build aims for games such as the photo above. You might wonder why some really old games are in there...Well, because the publisher thought it was genius to re-release them as platinum/classic/... and suddenly make a Pentium 1 game DX8 or above.
And this is my current XP PC (which is, in fact, my old XP PC which I've kept around 😀 ):
- Dell Dimension 9150 --> Dell DXP051 (3x PCI, 1x PCIx1, 1x PCIx16 as far as I know, haven't peeked inside yet)
- Pentium D 2x 3.20 GHz (XP calls it a Pentium 4, but that's apparently common as it is a double P4)
- 1GB RAM, I think 2x 512MB (I might have some extra RAM laying around --> does this have to be added in pairs or can I add a single bar because I don't have extra pairs?)
- SB Audigy (1 I think)
- ATI Radion HD 2600 Pro
(internet photo, mine also has a diskette drive and a gaping hole above a DVD writer)
One of the USB ports appears to be broken, but as it has something like 6 in total I'll survive. It has a working gameport with some MIDI stuff attached to it at the moment, but I don't need that so I can try to use some old peripherals on it.
I know these PC's are from the golden age of motherboard capacitors, but so far the PC works just fine so let's put that argument aside for the time being. What do you think of the config? Do you see some "lots of bang for the tiny buck" upgrades? Or things that I should not upgrade at all?
I remember that it could play HL2 quite OK. Crysis works, but I have to put most stuff at "low" and no AA if I want to play smoothish at a decent resolution (1280*1024).
