First post, by Gavrilo
Hello guys, whatz up. I hope you are doing fine. One short question. I have Amptron PM-8600 motherboard revision 5.5. There is USB header on it. So I connected bracket with two USBs, started my machine, but there is no USB present, whether in My Computer nor in the device manager. In BIOS there is no USB option neither. I am running Windows 98 FE. What options do I have to get the damn thing running? Thanks.
Reply 1 of 15, by Repo Man11
It's pretty odd that there's no USB settings in the CMOS. If the ports are functional, they ought to show up in Device Manager as USB or as an unknown device that needs a driver. Do you have the most up to date BIOS?
Reply 2 of 15, by Nexxen
Gavrilo wrote on 2025-09-17, 13:23:
Could you post a pic of your board?
It could be that the usb pins aren't in the same order as the bracket you are using.
Use a multimeter to check.
https://theretroweb.com/motherboards/s/amptron-pm-8600a#docs
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 3 of 15, by dionb
Hang on, incorrect pinout can cause devices not to be detected, but your USB root hub should be detected regardless. This motherboard has a Via VPX chipset. Did you install Via chipset drivers? If not, start there. Via still has them online (4-in-1 4.35), so does Phil's Computer Lab.
Be aware Win98FE is almost as limited as Win95 when it comes to USB. SE would be a lot better - but there you still need chipset drivers.
Reply 4 of 15, by Repo Man11
Some possibilities: you actually have a PM 8600A (double check), you have a PM 8600B with a PM8600A BIOS installed, or maybe you have the earliest BIOS for the board and they didn't include USB support in the initial release. Or maybe the board is old and flaky and the USB is non functional.
https://web.archive.org/web/19990225144208/ht … tml/main_fr.htm
Reply 5 of 15, by Gavrilo
Repo Man11 wrote on 2025-09-17, 15:49:
Hello Repo Man11, strange right? Good point, I will check the BIOS version tomorrow.
Reply 6 of 15, by Gavrilo
Nexxen wrote on 2025-09-17, 15:57:
Could you post a pic of your board? […]
Hello Nexxen, will do, but tomorrow. Tired like I don't know what.
Reply 7 of 15, by Gavrilo
dionb wrote on 2025-09-17, 16:17:
Copy that dionb, will check the drivers and install them. I also have those four files for usb support for Windows 95 somewhere on some diskette. Will try that too.
Reply 8 of 15, by Gavrilo
Hi all, I am sending some photos.
Nexxen, I compared the USB bracket cable connector with manual of the board, it is correct. I also checked it with multimeter with usb ports. Fine here as well.
Repo Man11, how can I check if I have PM8600A BIOS?
Thanks.
Reply 9 of 15, by Repo Man11
Gavrilo wrote on 2025-09-18, 15:29:
Hi all, I am sending some photos. […]
Thanks.
The BIOS string indicates that you have the correct BIOS for a PM 8600B, so if you have verified that your board is a -B then you have the correct BIOS. But there is a later BIOS and I wouldn't be surprised if it enables or enhances the USB functionality of your board. The first revision of the board shipped with non functioning USB ports, and in the summer of 1997 needing USB ports was still a far off thing for most. A motherboard shipping late in the summer of 1997 that would need a BIOS update for working USB ports wouldn't surprise me at all. https://theretroweb.com/motherboards/s/amptron-pm-8600b#bios
What shows up in Device Manager now? You should see either a USB hub or at least one unknown device.
Reply 10 of 15, by Gavrilo
Yes, version of the board is 5.5, this was clear from the beginning before I posted this issue. I see, so I have the first bios from those two bioses available for this board. I haven't tried those drivers dionb suggested, so I haven't gotten anywhere yet. Drivers are downloaded, all I have to do is put 'em on diskettes and try 'em. For which I will have space tomorrow. Will keep you informed.
Reply 11 of 15, by Kouwes
I have the same board, same BIOS and also 5.5.
You need to activate „OnChip USB“ in the BIOS and that unlocks USB keyboard support. I can‘t test it since mine is a pure DOS 6.22 system.
Edit: I do have a USB bracket from an Asus P4B533 board but I‘d have to dig it out from storage.
Reply 12 of 15, by Gavrilo
Hi Kouwes, thanks for the sugestion, but as I mentioned in my first post, I do not have any USB related option in BIOS settings.
A bout the drivers dionb suggested, they turned out not to be chipset drivers, but VIA Service Pack Setup program, which provides support for VIA ATAPI Vendor Suport Driver, AGP VxD Driver, IRQ Routing Miniport Driver and VIA INF Driver 1.40a.
But I tried to connect the bracket again on the board and now I see in Device Manager USB controller, but without any driver (strange, because I am sure it wasn't there before or maybe I just overlooked it). It seems that the board has USB support already provided by the system, so I am gonna try to install USB driver which I used for my other machine with Windows 95b where I have VIA USB PCI card.
Reply 13 of 15, by Gavrilo
Well there is one more thing. I have to confess, that I didn't mention one thing. From the 4.35 VIA Service Pack Setup program I installed the 3rd and 4th driver, so maybe this caused that there is USB controller in Device Manager, not what I wrote earlier: "It seems that the board has USB support already provided by the system".
Reply 14 of 15, by Gavrilo
Apologize to all. Maybe I was just too tired when I was posting this thread. I have found the USB option in BIOS. Unbelievable. So now when I enabled it and system started, it showed me those windows about finding a new hardware. It asked for some files from Windows 98 installation disk, from BASE5.CAB, so now I have USB main roothub and VIA VT83C572/VT82C586 PCI to USB Universal Host Controller in Device Manager. Now all I have to do is find some driver for my USB mass storage device a.k.a. USB key as we call it here in Slovakia. Any suggestions? I tried nusb33e and nusb36 but it is for W98SE.
Reply 15 of 15, by Gavrilo
Guys I did it.
I mentioned before that I will try to install after I deal with the USB ports the driver I used in Windows 95. And it works.
http://toastytech.com/files/cruzerwin95.html.
Unfreakingbelievavle. Now I have in My Computer removable drive and in Device Manager USB Mass Storage Port.
Thanks to all.
