First post, by DoZator
DoZator
Offline
Hello, I encountered a problem when running 86Box under Win98 (With KeX) everything works fine (You can go to the menu, configure the configuration, connect disks), but keyboard input does not work and I get stuck at this point:
I also checked "PCem 8.0" and there is no such problem - everything works well and keyboard input too.
Can I do something about it and fix the keyboard somehow? Thank you.
