First post, by analog_programmer
This info from the official Lo-tech XTIDE-wiki site has long since ceased to be adequate (probably it was for the very early XTIDE builds):
Yet it is simple and clear which prebuild file what system fits based on the CPU:
The attachment early-versions.jpg is no longer available
  • "ide_tiny.bin" - "potato" version (works on everything)
  • "ide_xt(l).bin" - for 8088/8086 and newer
  • "ide_xtp(l).bin" - for V20/V30 (it is unclear if it will work on 80188/80186)
  • "ide_286(l).bin" - for 80286 and newer (it is unclear if it will work on 80188/80186)
  • "ide_386(l).bin" - for 386SX/386DX and newer
Later (before ver. r625) the names were changed to even more IBM-ish scheme, which is.... let's say, not the "42-ish" thing, but still acceptable:
The attachment later-up-to-r625.jpg is no longer available
  • "ide_at(l)" = "ide_286(l).bin" - for 80286 and newer (it is unclear if it will work on 80188/80186)
And since version r625 (including) we have this:
The attachment r625-and-newer.jpg is no longer available
  • "ide_at(l)"= "ide_286(l).bin" - for 286 and newer (it is unclear if it will work on 80188/80186)
  • "ide_ps2(l).bin"- ??? !!!
"ide_ps2(l).bin" - what's the usecase for this one as PS/2 system models are with different CPU - 8086; 80286; 386SX/SLC/DX; 486SLC2/SX/DX(2, 4) (and even Pentium for some PS/2 server models)?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 1 of 4, by Jo22
^Maybe BIOS related somehow?
The PC/XT, PC/AT and PS/2 platforms have all different BIOSes in some ways or different standard i/o ports for things like HDD.
The interrupt vector tables might be different, too. Variables in memory, I mean.
Now, the AT BIOS is more or less a superset of the PC BIOS or XT BIOS.
It added new BIOS calls for Extended Memory and so on.
But the PS/2 BIOS was merely partly AT BIOS compatible, as far as I know.
Or let's say the PS/2 platform was both a fork and a dead-end.
It added features to AT BIOS that didn't went back into AT platform.
Things like memory above 64MB, larger HDDs etc.
That's why himem.sys and certain OSes have dedicated PS/2 support.
The PC BIOS and XT BIOS look same but differ in HDD support.
The PC/XT (Model 5160) had a bigger PSU and its BIOS supported loading an
Option-BIOS containg HDD BIOS (a feature which also was welcomed for EGA/VGA BIOSes).
Funnily, later BIOS revisions for the PC (Model 5150) added support for this, too if memory serves.
So there's an overlap between PC and XT BIOS at some point.
But even without this, there were some workarounds to use HDDs in PCs..
Please don't ask me which, I'm just a layman here. 😅
Reply 2 of 4, by analog_programmer
In this case, can we assume that "ide_ps2(l).bin" is strictly IBM PS/2 XTIDE BIOS ROM, while all other variants are more of "universal" kind?
For example, I only used "ide_386l.bin" in ISA LAN card (with XTIDE BIOS flashed in EEPROM) for one 386SX build and it worked fine. Later I tried the very same LAN card on s.7 mobo and it also worked without any changes. But I have no experience with the other variants of prebuild XTIDE ROM files and I'm just curious if PS/2 variants "ide_ps2(l).bin" are interchangeable (in some extend) with "ide_xt(l).bin", "ide_at(l).bin" and "ide_386.bin". Obviously this can't be understood from the file names and the related information in XTIDE-wiki is outdated.
P.S It would be much simpler and clear, if non-IBM naming is applied:
  • "ide_88(l).bin" - for 8088/8086 and newer
  • "ide_v20(l).bin" - for V20/V30
  • "ide_286(l)" - for 286 and newer
  • "ide_ps2(l).bin"- for IBM PS/2 systems only??
Reply 3 of 4, by Jo22
Hi, yes, I think so. I'm just a layman, though. 😟
The (l) versions are the Lite versions without the menu, if memory serves.
Reply 4 of 4, by analog_programmer
Jo22 wrote on 2025-09-18, 09:08:
Actually it's in reverse. In the end of the file names the letter "l" stands for "large version" i.e. with all the possible BIOS modules included. So, the "non-l" files are the lighter versions of the "l" files.
P.S. But you're somehow "right" in your confusion, as at first look someone may think, that the letter "l" is really for "light version". It would be better, if the letter "f" was used instead - as for "full version", 'cause who the f*ck reads the f*ckin' manual 😁
