First post, by renejr902
Hi! Please check the picture and tell me if this laptop will support windows 98 ? At least Centrino Pentium M cpu, i know i can get a geforce fx works in win98 with omega driver 45.23 driver. i suppose it will works
It has a Pentium M cpu because its centrino
it has a geforce FX card
Its a Toshiba, its for a deal on a lot, i can't know the model for now.
If you know the toshiba model, tell me please.
I hope it has a geforce fx 5500 or 5600, but it could be a fx 5100 or 5200 .
The include the same laptop another time but with " special edition " wrote in the left corner. thanks for help and answer
3 pictures of the 2 toshiba laptop
Reply 1 of 13, by dionb
The GeForce FX dates the laptop between early 2003 and somewhere in 2005.
Looking at the Pentium M platform, that matches the 855 series chipsets (early 2003) or 915 series (early 2005), but GeForce FX (including the mobility version) use AGP so it would have to be 855, not 915.
That's good news for Win98SE support as the 8-series chipsets are supported whereas the 9-series is not (although it can run). So the basics will work. As for all the other hardware in there - you'd need a positive ID on the system to be sure of that. Most likely most of it will work.
Reply 2 of 13, by keenmaster486
Almost certainly not.
World's foremost 486 enjoyer.
Reply 3 of 13, by renejr902
dionb wrote on 2025-09-22, 22:41:
wow cool. i will buy the lot.
( i need at least geforce driver and sound driver, dont need any network card working. but i dont know how win98 will work with a pentium m and the performance vs my p3 dell inspirion
1. If its a fx 5200 go , do you think i will have more fps than my inspirion 8100 p3 1000mhz with a geforce2go ? thanks for answer.
2. Is it a 16/9 or 4:3 lcd screen ?
Reply 4 of 13, by RetroLizard
Not a 4:3 display - those are almost always uniformly square.
Reply 5 of 13, by Ozzuneoj
Not sure if this is the exact model, but if it is, your guess at the specs seems spot on. 😁
https://www.cnet.com/reviews/toshiba-satellit … u02202c-review/
EDIT: Also, I want to know what's in the desktop at the bottom of the stack. 😀
Reply 6 of 13, by RetroLizard
Ozzuneoj wrote on 2025-09-22, 23:54:
Not sure if this is the exact model, but if it is, your guess at the specs seems spot on. :D […]
It's a Compaq Deskpro. Dunno which model.
Reply 7 of 13, by Ozzuneoj
RetroLizard wrote on 2025-09-23, 01:28:
Looks a lot like this one:
https://retrocomputing.stackexchange.com/ques … -compaq-deskpro
Reply 8 of 13, by renejr902
Looks like this Compaq. Thanks for the url for the Toshiba, it seens to be the M30
3 others pc in the lot
no idea what are the 2 pc to the right
Reply 9 of 13, by Ozzuneoj
Ozzuneoj wrote on 2025-09-23, 01:44:
Interesting mystery machines. Both the beige ones look like custom builds. I like to try to guess the specs of stuff like this so I'm going to say the tower is probably holding a socket 478 P4 or Athlon XP, maybe early Athlon 64 or Sempron (Socket 754).
The desktop is anyone's guess... the LG DVD drive looks quite a bit newer than the case. So, I would bet that it either has uncharacteristically modern parts in it (like, Core 2 duo or later) or it is something from the early SATA days with VIA or Intel chipset. Maybe some goofy ATI chipset thing.
The black one with the Coolermaster case obviously has a P4 case badge. Looks a bit fancier. I'm guessing a slightly more upscale build with a low\mid range GPU. Sadly, the caps are bad on the motherboard, because that's how these things tend to go. 🤣
Please post back here when you get them to let me\us know what was really in them. 😁
Reply 10 of 13, by renejr902
Ozzuneoj wrote on 2025-09-23, 02:34:
Interesting mystery machines. Both the beige ones look like custom builds. I like to try to guess the specs of stuff like this s […]
yeah sure. Check my other lot, my other topic, i make an offer of 700$, a lot of pics
Reply 11 of 13, by RetroLizard
I love that Coolermaster case. It's a very significant part of my childhood.
Reply 12 of 13, by renejr902
RetroLizard wrote on 2025-09-23, 03:35:
yeah i want to buy it only for the case.
Reply 13 of 13, by RetroLizard
Do it. Have fun with the case! 😄
