First post, by montezuma iii
Dear guys and dolls,
Hi:
I've got a Frael King PC, with NEC V20 cpu and CGA integrated graphics: I'd like to install an external 8 bit isa VGA card and I think I've to disable the internal CGA chip:
Chatting with ChatGpt It saids to obtain the "NOCGA" .exe (or .com) utility, wich I'd find in software packages like Norton Utilities, PC DOS 5/6 OEM installations, Checkit, Sysinfo or whatever: It hasn't a precise info about where to find It.
The point is right this: where could I find It?
Or are there others ways to disable the CGA chip? Could I remove It or I'd do damages? (but It's an SMD chip and I'd have to bring the pc to a reparation center); Should I remove the Video RAM chips too?
Thank You very much indeed for the help.
