Shponglefan wrote on 2025-09-28, 19:52:
Depends on the specific models of AWE32 and SB32 in question and what you plan to use them for.
If one of those cards has a genuine OPL3 chip, I would use that in the Pentium system since I imagine that system is more likely to be used with DOS games that use FM synthesis.
I plan to use both with DOS and also test other operating systems, on the classic Pentium Win95, 98, etc. just to test them, for fun. On the Pentium Pro, both DOS and other... even Win2000, XP, but it should focus on WinNT4. I will not install just one operating system but multiple on different compact flash cards. The awe32 has the OPL3 chip while the sb32 does not. Perhaps since the Pentium Pro is rarer, I was thinking of installing the card without OPL3 since between the two computers I will use it less to preserve it.
