First post, by Linoleum
- Member
I'm having trouble with a stubborn Mitac 286 system—also known under various names like Paragon 286, MPC-2000SL, and PWA-286. Unfortunately, documentation is scarce, especially when it comes to the maze of jumpers on the motherboard. I'm running into a few frustrating limitations:
- RAM is capped at 640KB
- Only 5.25" floppy drives work—both with the onboard controller and a multi I/O card
- IDE hard drives won’t work—neither CF cards nor actual drives are recognized
Given these constraints, I'm wondering if this system could benefit from PicoMEM.
My question is: Can PicoMEM bypass the floppy and hard drive controller issues entirely, and if so, are there any caveats I should be aware of?
P3 866, V3, SB Audigy2
P2 300, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, WavetablePi & PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16, WavetablePi
SC386SX 25, T8900, Audician32, MT32pi
