The big IC there is likely the multi-IO, not the IDE logic.
https://www.alldatasheet.com/datasheet-pdf/pd … 2/TL16C451.html
(the --452 is a version of this chip with an additional parallel port, and some other goodies.)
(on the assumption that TV is a variant of Texas Instruments, as per above)
The SPC2052F is apparently an NEC compatible floppy diskette controller chip.
Looking at the traces (my eyes are crap anymore), it looks like the chip that actually drives the IDE controller is the small quad package there, with GG05 JAPAN written on it.
I cant seem to find a data sheet on this IC though.
I am guessing that this is a very simplistic 16bit IDE controller with no real meat to it, other than some latching and address decoding.
I presume that you want to identify this device so that you can configure the DIP block. More than likely, since we have silkscreening on the board that identifies where IRQ assignments are given, this dip block controls the IO base addresses of the IDE controller, the serial ports, the game port, and the LPT ports.
I would suggest going through it in a binary sequence and recording what happens with each toggle.
