First post, by Guest
Trying to run TTDLX on xp and it was suggested to try DOSBox!
However I am still having problems to get it to run, i was wondering if someone could give me some further help! I have already tried some of the guides in the guide forum.
I was wondering if anyone could help me further. The error that appears when I try and run the program normally is....
When I first try to start running it comes up with the following error:
16 bit MS-Dos Subsystem
C:\WINDOWS\system32\cmd.exe
The system cannot open COM2 port requested by the application.
Help please?
Reply 1 of 3, by eL_PuSHeR
I think 16 bit MS-DOS Subsystem doesn't have anything to do with DOSBox. Are you sure you are using DOSBox? or are you using windows NTVDM (cmd.exe) instead?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 3, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
You will not get any help if you do not bother writing details (mounting etc.)... Anyway you do not use DOSBOX according to the reported messages... And there is no DOSBOX 6.0...
And you are in the wrong forum, I move this to DOSBOX Games/Apps...
Mirek
