First post, by aspiringnobody
Hello all,
I bought a broken (as-is) V2 from eBay expecting to need to replace the TMU. However now that it’s here, I’ve been able to inspect the damage and I’ve found that the only pin that’s actually broken is pin 27, which I believe is VCC.
Anyone have any thoughts on just disconnecting that pin entirely? Assuming I can get the pin out from behind pin 28 (it’s wedged behind it) without breaking pin 28, do you think missing one VCC connection will cause any damage?
I’ve ordered a TMU just to have one in stock, but if I can avoid the micro-soldering I would prefer to, since changing the TMU is IMO very risky.
