First post, by Grzyb
- l33t
I'm trying to install this NIC - https://th99.infania.net/n/E-H/40145.htm
The most important part is at the bottom:
"Different drivers must be used for the National & the Fujitsu chipset cards, & are not interchangeable."
I've found some drivers, but they seem to be for the National variant, and don't work with my card.
I've also found some mentions:
"GQLANDRV.ZIP 157K Complete LAN_DRV_207 disk. Fuji Chipset. (Use pkunzip -d)"
"GQLANDRV.ZIP 951006 160227 6505/6506/6507 Fujitsu Chipset Distribut"
http://www.theflatnet.de/pub/hardware/3com/index.txt
...but can't find the GQLANDRV.ZIP itself!
Any help?
Nie rzucim ziemi, skąd nasz root!
