First post, by chinny22
- l33t++
This is the PC I rescued from an abandoned factory earlier this year.
Hardware saved from Abandoned Factory
I'd given it a good wash about 3 months ago knowing it would be about that long till I had a chance to have a proper play with it.
This way it would be clean and all dried out when I was ready.
I'm not familiar with the company name on the case badge but noticed it was a local phone number.
Quick Google shows the company is still running although I suspect under different management from when this was built! warranty stickers on the ram are dated 11/92
Someone had cut the PSU's cables to the motherboard. Not sure if that meant the PSU was faulty or not but wasn't going to test my luck, I replaced it with a spare AT PSU I already had.
From the POST string and https://theretroweb.com I managed to identity the motherboard as a DataExpert OPTI-495SX with a 386 DX40 installed although does also support 486's
it still had the Barrel battery when I got it and had leaked a little but didn't seem to be that bad.
It also had 4MB of RAM
SIO-11A I/O board
Trident TVGA9000B Video card
Sony 1.4MB Floppy.
At first it didn't boot, but that was "fixed" by moving the video card down a slot.
So I got excited reassembled everything.
Annd then got stuck. The PC doesn't seem to detect the FDD or HDD.
I/O card seems to be jumped correctly, ribbon cables are all ok. Tried another I/O card. still no change.
That (as well as real life things) had taken best part of the day and decided to call it quits.
As I don't really want/need a 386, it's more just a mess around project. Really I wanted the case for a MMX build but more on that later
