First post, by rfdes
I am in hope that someone might be able to shed some light on a NOS, Sharp, 800x600 TFT panel from around 1998. I have an old win2K piece of test equipment that supported 800x600 TFT (TTL) panels. The original panel has died and I found a super cheap, new, Sharp model LQ10DS05 (10.4", 800x600) model that I thought would work without issue. However, there is apparently some timing anomalies preventing this Sharp panel from being compatible. Searching for a detailed datasheet has been futile, so I could use some help finding a datasheet for this panel. Sharp also made a model LQ10DS01 which I believe is the same in regarding to the timing specs.
My plan, once I understand the timing differences, is to patch the bios in order to modify the timing as needed. Sounds like a challenge, I know, but it should be fun to try. It's all about just having fun!
So if anyone has any knowledge regarding this series of panels, your help would be appreciated.
Thanks
Jim
