First post, by egbertjan
I have an ASUS P2B rev 1.12. I see in the manual for rev 1.10 (I can't find the one for 1.12, unfortunately) that it should be able to handle an FSB of 103MHz and 105MHz via jumpers. If I set the jumpers for 103MHz, I get 133MHz and PCI 44.33MHz. The jumper settings for 105MHz are the same as those for 140MHz and 35MHz PCI. The jumper settings for 110MHz, 112MHz, 115MHz, and 120MHz are correct. Does anyone know how to set the jumpers for 103MHz and 105MHz?
Here's the picture of how it's described in the manual.
