First post, by ThePfhor486
- Newbie
Hi Guys,
I really need the communities help with this one.
For the past month, I've been acquiring many vintage parts for the 486 build I always wanted, many of which are new old stock.
While testing the components, I am unable to boot from any of my floppy drives, all of which are good on other systems. I am sure my cables are connected correctly to both the drive and controller. I've also checked that the controller jumpers are configured correctly and I can't see any issues. Drives are configured in the BIOS. When I boot the system with only the video card and controller connected to the board, I get a seek test from the drives and no disk errors from POST. After the system POSTs, it tries to read the known good MS-DOS install disk, and gives any of the following errors:
Disk I/O error
Non-system boot disk
Disk boot error
I did happen to get a "Starting MS-DOS" prompt once by hooking up the 3 1/2" Drive A: improperly behind the twist in the cable, but it stopped attempting to read the disk and the system hung. Otherwise, I just get any of the above errors. I've also attempted clearing the CMOS after changing the battery, and played around with several BIOS settings. The drive tests good in other systems as does the cable. I've also tried different ISA slots on the motherboard to no avail. I changed bus speeds, disabling L1 and L2 cache, disabling everything except the FDD, disabling every IRQ except the floppy, disabled video BIOS shadow and enabled floppy drive swap. No combination of these have helped.
Here are the specs of what is currently connected to the system.
Motherboard: EFA 4DMS-HL3G
CPU: Am486 DX4-100 (A80486DX4-100SV8B)
L2 cache: 256kb
Memory: 32 MB 2x16mb FPM (4Mx36)
Video card: Western Digital WD90C33-ZZ VLB
Controller: DFI MIO-550 ISA
HDD: Western Digital Caviar 33200
Power supply: New AT replacement PSU 300W
FDD: 1.44mb 3 1/2"
I'm hoping there is a conflict somewhere, I would really hate to think that there is an issue with the controller, after all this is a new old stock part never used before. I can provide any pictures if anyone requests. Any input would be helpful, I am going insane trying to solve this issue. Thank you!
