Ok Thanks, I thought they were present in that manual, but you can't select multi 3.5X and FSB 100, for a 350 you should keep th [โฆ]
Ok Thanks, I thought they were present in that manual, but you can't select multi 3.5X and FSB 100, for a 350 you should keep the FSB at 66, and raise the multi to 5X (333 MHz), or use the multi 5.5X (366 MHz), keep in mind that the VCore must be 2.2V.
It would be very simple if your K6 was a CXT, with that you put multi 2X and automatically becomes 6X, but you get 400 MHz, I don't think you would have problems, but personally I recommend the 5X or 5.5X, because at 400 MHz I don't think you would have much better performance.
As for the BIOS, I don't think you'll have any problems, but I think that at most, it doesn't recognize the CPU correctly, this could happen if you use the original version.
Probably, what you need, would be contained in later versions of the manual, or they are secret settings.
