First post, by andrea
Hello,
I have a dumb question for you all.
How is the cover on the DB connector side, as used in breakout cables for AT boards (for example), called?
The black one in the picture, with the moulded-in nuts and the flat cable shaped opening.
I'm looking to buy a few spare ones without having to get the whole cable and I don't know which query to use.
Shell, shroud, cover, ecc.. only get me the usual external connector cover, the two halves with thumbscrews and a round cable opening.
Thank you,
andrea
