First post, by renejr902
Hi! I have a 486 motherboard that i repaired. Works with a 486 sx cpu, but not with a dx 33 cpu. need jumper info, thanks
I can't find this exact motherboard online, only some similar with the opti chip 82C495 SX.
The motherboards i found are enough similar, but jumpers dont seem the same.
Thanks for help
Reply 1 of 5, by dionb
It would help to have a clear pic of the whole motherboard from straight above. Only the middle pic here is in focus and good enough to make out jumpers.
Best I can do with these pics is suspect the Shuttle HOT-409: https://theretroweb.com/motherboards/s/shuttl … hot-409-ver-1.x ; JP7 and JP9 seem to match, can't judge anything else.
Was that one of the boards you already found? If not, which others did you find and how?
Reply 2 of 5, by renejr902
dionb wrote on 2025-10-27, 22:30:
I will do best pictures later. The picture 5mb limit give me trouble with my new phone that cant take picture below 12megapixel. i have to edited my picture and they become tiny at 5mb 🤣.
i found this:
https://theretroweb.com/motherboards/s/dataex … opti-495sx#docs
and this:
https://theretroweb.com/motherboards/s/dataex … x-3-486wb-cache
I will check your link right now
EDIT: your link seems good, i think its exactly this motherboard. i will let you know thanks a lot
Reply 3 of 5, by renejr902
This is where i repaired, the battery leaks a lot. everything works with the 486 sx 33. Now i try to move the jumper for the 486 dx 33 and let you know if it works 😀
( keyboard connector was glued with epoxy )
( new battery )
( some lines were bad and a resistor )
Reply 4 of 5, by dionb
renejr902 wrote on 2025-10-27, 22:43:
I will do best pictures later. The picture 5mb limit give me trouble with my new phone that cant take picture below 12megapixel. […]
i found this:
and this:
They have a pretty different layout. Same chipset though. Nice boards, I have the second one 😉
Great - enjoy 😀
Reply 5 of 5, by renejr902
dionb wrote on 2025-10-27, 23:12:
They have a pretty different layout. Same chipset though. Nice boards, I have the second one ;) […]
i found this:
and this:
Great - enjoy 😀
with the correct jumper the 486 dx-33 works perfect. Thanks a lot. This is a board i keep in my collection, i will play some dos games this evening with it 😀
