First post, by 3dfx_fan
Hi everyone,
I'm building a retro setup with an Asus P3B-F motherboard (BIOS 1008.004 modded for PPro support from oezmen.eu) and a Pentium Pro 200MHz (256K) in a Slot1-to-Socket8 adapter (Epox KP6-0 . 00). POST passes fine, I can enter BIOS, set everything up (FSB and multiplier), and even install Windows 98SE/ME. However, the system freezes during boot right before the desktop loads (probably while loading/intializing some drivers - it seemed to install/intialize monitor correctly and had probably problem with something after monitor). So I entered safe mode installed some chipset drivers and restarted. Now it hangs on the "New Hardware Wizard" trying to install drivers for the "Intel(r) 82443BX/ZX/DX Processor to PCI bridge" (after installing Intel chipset INF in safe mode).
**Hardware details:**
- Motherboard: Asus P3B-F (440BX chipset)
- CPU: Pentium Pro 200MHz 256K (single, via Slot1-Socket8 adapter) - tried with various FSB and multiplier combos ranging from 133Mhz to 200Mhz (did not go over 200Mhz)
- RAM: tried 2 configs: 128MB and 1GB PC133 SDRAM
- GPU: nvidia Quadro2 MXR
- Storage: IDE to SATA HDD
- Other: no other PCI and ISA cards, IDE CD-ROM, different mouse and keyboard combos (PS/2 and USB - no difference)
- PSU: FSP Group ATX-300GTF (1) 300 WATT ATX 20-PIN, ATX12V 4-PIN, 5x MOLEX
- BIOS: 1008.004 modded for PPro support from oezmen.eu
**Symptoms:**
- **Win98SE:** Hangs in late boot phase (mouse cursor visible, hourglass flickers, detects/installs monitor briefly, then full freeze). Safe mode works fine. After chipset drivers install in safe mode, next normal boot triggers the wizard and hangs.
- **WinME:** Similar hangs, sometimes BSOD (e.g., protection errors, VxD faults) during 2nd part of OS install or boot, especially at serial key enter prompt.
- **Win95 OSR2.1:** Boots perfectly! Installed chipset drivers (Intel INF 3.20), and it runs quite stable – no issues (except 1 random freeze).
- **NT4/2000 (testing):** did not test.
**What I've tried:**
- BIOS tweaks: PnP OS = No
- No PCI/ISA cards, tested minimal config.
- Reduced RAM
- Flashed modded BIOS for PPro compatibility from oezmen.eu
- different mouse and keyboard combos (PS/2 and USB - no difference)
This seems tied to the PPro + adapter on 440BX. I have no such problems when using Pentium II.
Is it the aggressive PnP in 98/ME clashes with the PCI bridge detection, while 95 (and maybe NT) is more forgiving? Wondering if it's a timing/cache issue with the adapter?
**Questions:**
1. Anyone running similar Pentium Pro + Slot1 adapter on P3B-F or other 440BX boards with Windows 98(SE)/ME? Any specific BIOS hacks or microcode patches?
2. Would switching to 440LX (e.g., Asus P2L-97) help, or is ZX/LX worse?
3. Patch for Win98 PnP to skip PCI bridge? Or hotfixes?
4. Is that the case of the adapter/converter? Are there better ones?
5. Does Windows NT(4)/2000/XP work without issues with such a setup? I did not test.
Thanks in advance – love Vogons for these deep dives!
Cheers,
3dfx_fan
