Intel 486 Rebuild
First post, by TheIpex
As stated in the title, this is more of a rebuild than a build.
Some Backstory
This machine has a high sentimental value to me; I had a similar model as my first computer. (Identical case but with the 486SX 33MHz inside)
Years later I had the chance to acquire this machine. I don't use it on a regular basis, it comes out on special occasions.
Games I've played on it in the past are mainly shareware titles:
  • Castle Of The Winds
  • Block Breaker
  • Home Stretch
  • Slicks 'N' Slide
  • Dinosaur Predators
  • Wiggly Worm 94
  • Toad
  • Jetstrike
  • Skyroads
The Parts
I'll also list what parts are original to the machine and what I'm adding.
Processor: Intel 486DX2 66MHz SX955 (New)
P24D with writeback capability. This is a very mild upgrade over the existing 486 Overdrive that was already present in the machine.
CPU Cooler: Cheap heatsink with a 3D-printed mount, 40mm Noctua Fan (New)
I had clearance issues that needed to be overcome, see the build section below.
Motherboard: Asus VL/I-486SV2GX4 Revision 2.0 (Original)
I've heard mostly good things about this baby AT board, and it's never given me any trouble. Outfitted with 256kb of cache.
I'm using the modded bios from this post.
RAM: 2 x 16MB NEC 60ns FPM (Original/New)
Simply adding an additional SIMM.
VGA Card: ECS VI-710 | Cirrus Logic GD5428 VLB 2MB (Original)
Equipped with the somewhat superfluous memory upgrade.
I/O Card: Winbond/Winic Multi-I/O Card (Original) Replaced with QDI Q6580W VLB Card
I have very little information on this card. No complaints either.
Hard Drive: Conner CFS425A 425MB (Original) Replaced with Seagate Barracuda II ST315324A
Still trucking along with no bad sectors.
Sound Card: Creative Sound Blaster Pro 2 CT-1600 (New)
I much prefer this card over the cheap clone card I had as a kid. Everything just works with minimal fuss. The CDROM interface will be seeing some use too.
Optical Drive: Panasonic / Matsushita CR-563-B 2x (New)
My first (and likely last) foray into proprietary CDROM drives.
Floppy Drive: Sony MPF920-E (New)
Replacing the also-pictured original drive which has ceased to function.
Ipex case and power supply (Original)
The power supply is an Ipex-branded Seventeam model. Very clean inside: caps look good but given the age will need replacement eventually.
Operating System
DOS 6.22 + Windows For Workgroups 3.11
It's what I used back then, and I see no reason to change now.
The (Re)Build
Everything went back together the same way it came apart, with the heatsink being the only hurdle:
I really wanted a fan on the heatsink, however the CDROM drive prevented me from mounting it on top. I instead elected to side-mount it.
A thin lip between the CPU and the socket secures the square bracket in place, and clips keep the heatsink centered over the CPU. The fan housing is then screwed directly to the side of the heatsink. Thermal paste rather than adhesive makes this setup easier to remove if required.
You can slide a sheet of paper between the heatsink and CDROM drive, but not much else.
Beyond that, it was simply a matter of just cramming everything back in.
I also did a fresh reinstall of DOS/Windows and was delighted to find the CDROM drive worked as expected after loading the appropriate driver.
Benchmarks
DOS
Courtesy of Phil's Benchmark Pack
Windows
WinMark
Windsock
Wintune
This is the computer that triggers the full-blown nostalgia for me. I'm still livid that I couldn't hold onto the original I had as a child, but I'm pleased that I have a second chance to own one of these awesome machines.
Intel 486DX2 66MHz
Intel Pentium MMX 233MHz
Intel Pentium III-S 1400MHz
Reply 1 of 20, by pete8475
Very nice, love the CPU fan mount.
aka pete4237.5
Reply 3 of 20, by Intel486dx33
Nice fan.
Is anyone selling these fan mounts online ?
I don’t have a 3D printer.
I would like one for my Intel 486dx4 Overdrive CPU.
Reply 4 of 20, by TheIpex
Intel486dx33 wrote on 2025-11-22, 09:37:
Nice fan. Is anyone selling these fan mounts online ? I don’t have a 3D printer. I would like one for my Intel 486dx4 Overdriv […]
Nice fan.
I don't believe so, at the very least I've never seen anyone selling them.
Intel 486DX2 66MHz
Reply 5 of 20, by badmojo
Those are classic 486 specs, fantastic 👍 I had that motherboard for a while - it was almost too easy to work with. 486's are suppose to fight you every step of the way 😋
My only comment is that perhaps a VLB IO card would be a better option speed wise?
Reply 6 of 20, by Intel486dx33
I have that same sound card in my 486 computers
Distortion at high volume levels is a known problem.
I found that if you mute the mic and adjust the volume dial on the back of the card to 1/2 or 3/4 percent
you get less distortion.
You can always turn up the volume on your speakers or in Windows or DOS program
Its a tricky situation.
You need to make adjustments in Creative program. system configuration files, Windows, DOS, and physical hardware volume knob levels to get the cleanest sound.
I wound invest in some good speakers
2.1 system with subwoofer.
Reply 7 of 20, by Shponglefan
TheIpex wrote on 2025-11-22, 00:05:
That is a really nice fan mount! I've side-mounted fans before using zip ties, but this is a much more elegant solution. Nicely done!
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 8 of 20, by TheIpex
badmojo wrote on 2025-11-23, 08:13:
Fair point, I don't have much experience with VLB IO cards.
Intel486dx33 wrote on 2025-11-23, 11:43:
I have that same sound card in my 486 computers Distortion at high volume levels is a known problem. I found that if you mute th […]
You need to make adjustments in Creative program. system files, Windows, DOS, and physical hardware volume knob levels to get the cleanest sound.
Indeed, I have been wrangling with this. Thanks for the heads up.
Shponglefan wrote on 2025-11-23, 17:21:
Thanks, I feel much better knowing the CPU is getting active cooling.
Intel 486DX2 66MHz
Reply 9 of 20, by chinny22
Very nice and very similar to my first PC which is listed here, but will skip ahead to the post with my less then elegant fan "mount" yours is definitely much nicer!
Re: Osbone 486 DX2 66 VL-Bus (My 1st PC ever)
I second VLB I/O if you can. It shouldn't behave any different to an ISA card as far as "installing" goes
My PC also came with a Conner 420MB HDD, they make a very distinct sound I really like.
Your doing well to have a working Panasonic CD-ROM mine died years ago and know they are sort after by the 3do community.
I find if you have a 486 on the network and a large HDD you don't really need a CD drive. Network also "forces" me into WFW to access shares.
Overall very nice system and should bring back many memories
Reply 10 of 20, by TheIpex
chinny22 wrote on 2025-11-25, 06:24:
I just had a read through your post; it looks like a really solid system! I very much like those slim desktop style cases. I'm currently trying to track down a slim Dell OptiPlex (pictured), which was my first Pentium PC, but it's turning out to be a bit of a unicorn.
The attachment s-l1200.jpg is no longer available
Ok, I will keep an eye out for a suitable VLB I/O card.
I'm planning on opening it up soon and checking the caps.
Cheers mate.
Intel 486DX2 66MHz
Reply 11 of 20, by Jasin Natael
That is a sweet build. Makes me want to drag my 486 build back out. Been thinking of removing the Cyrix 5x86 and reverting back to the DX4.....
Reply 12 of 20, by TheIpex
Jasin Natael wrote on 2025-11-25, 14:25:
Thanks, I did consider getting a DX4 for this build but I didn't want to mismatch with the sticker on the front 😁
Intel 486DX2 66MHz
Reply 13 of 20, by TheIpex
I've made a couple of changes to this machine:
Firstly, I've swapped out the ISA I/O card for a VLB one: The QDI Q6580W.
I'm using the QDI driver in DOS and the Micro House driver in Windows.
Secondly, the hard drive. The old Conner drive is just too slow to take any meaningful advantage of the VLB card. I don't have a faster period-correct drive to use, so I've elected to use a Seagate Barracuda II with the 2.1GB limit jumper.
The effect on the Speedsys result is somewhat comical (Note a small CPU score decrease):
Finally, I was having some intermittent issues with the CDROM drive so I pulled it apart to clean the lens, reapply grease and check the "3DO gear" which was still intact. A few of the capacitors were leaking so I went ahead and replaced them all.
Here's the capacitor values if anyone needs them:
Happy to report that the drive now reliably reads factory-pressed CDROMs. (CD-Rs are of course a different story)
I'm pretty happy with where this machine is at now, If the CDROM drive gives me any more trouble I'll likely switch to a standard IDE model.
Intel 486DX2 66MHz
Reply 14 of 20, by AlexZ
There is an interesting phenomenon at play with random seek time. That Seagate HDD doesn't have much lower random seak than that Conner, but because it is restricted to a tiny proportion of its capacity by jumper, practical random seek time is really lower. The head has to travel small distance to access the 2.1GB capacity.
You should probably look for the biggest ATA drive that still has that jumper, i.e even 60-80GB one. You have a relatively modern ATA-100 drive, those came even with higher capacities. Unfortunately in more modern drives the jumper limited capacity to 32GB
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 16 of 20, by hilram
What an awesome build! Very good home-made cooling solution!
Reply 18 of 20, by Intel486dx33
My two cents.
1) get a CF card reader. I like the one from startech
2) get a network card 3com 3c509b combo or Intel pro-10
3) get a faster CDROM 4x or faster, I use a 52x
4) get some good modern desktop speakers with subwoofer. 2.1
Preferably get Two CF card drives. One for OS and the other for storage.
With a removable CF card you can swap out operating systems quickly
And backup your files quickly also
I use the network card to backup my 486 to my home NAS
I just map a drive and then quickly copy over the files to a folder on my NAS
I use a WI-FI extender to connect my network card to my WI-FI router.
TP-link or Linksys Wi-Fi extenders work great with the 3com 3c509b
Windows 3x and Win95 was designed for networks
Windows 95 was designed to support the 486dx-33 CPU.
I think Win95 is the best OS for the 486.
With the CF card you can push your CPU, Video card, Nrtwork card, CDROM. Etc to the limits
Basically the CF card will allow you to run your computer components to its optimal.
Forget about period correctness if you want to get the most out of your components
For me the CF card, 3c509b, and Fastest CDROM drive is a must and I use this in all my 486 builds.
They can run Win95 well, Play Video CDs, Run Office 97, etc.
Anything windows 95 can do the 486 can do it.
Also with the additional CF card you can backup your OS to the CF card then take to your
Windows-10 computer and burn the files to a CDROM disk this way you will have a hard drive image
Of you 486 build so you can preform a quick restore from CDROM disk using the xcopy command.
Hey, I found the fastest way to install Windows 3.11 to a 486 is to use the Gateway 2000 computer Restore
CD version 3.4. it has Win3.11 on it and DOS 5.0 you might be able to download it from CDROM internet archive website.
Link:
https://archive.org/details/Gateway2000System … way20001994_468
And with your current hardware and the components I recommend the drivers are included in Win95
And Win3.11 so installation is a breeze. Super easy.
Reply 19 of 20, by H3nrik V!
Intel486dx33 wrote on 2026-05-18, 12:53:
I'd avoid getting a too fast drive. Already 24x drives tend to spin up and down endlessly because it tries to read as fast as possible, fails, reduces speed, succeeds, ramp up speed, fail, etc. I get crazy listening to that. I always used software to limit optical drives' speed to avoid that ..
