First post, by MrFlibble
- Oldbie
Recently I found a freeware Breakout like game called GetOut by a certain Jouni Laukkanen, but I can't get it to work in DOSBox. It hangs with no messages, but DOSBox terminal output indicates corrupt MCB chain.
The game itself can be downloaded from a MikroBitti coverdisk using DiscMaster:
https://discmaster.textfiles.com/browse/33280 … ketit/GO100.ZIP
I tried using JEMMEX instead of the built-in memory managers, no effect.
Tried running the game in 86box but no luck either.
DiscMaster finds no other instances of this game.
