First post, by Hezus
I recently came into possession of three HP/Compaq T5000 thin clients. I've seen these types featured before on various YT channels as pretty capable DOS machines so I was curious to see what it was all about. Another curiosity: some models use the Transmeta Crusoe, which was a shortlived x86-compatible cpu that used emulation. Quite interesting!
I got my hands on 3 different models:
HP T5300 - A Transmeta Crusoe TM5600 @ 533 mHz
HP T5515 - A Transmeta Crusoe TM5700 @ 800 mHz
HP T5700 - A Transmeta Crusoe TM5800 @ 1000 mHz
There are various models of the t5000 with different configurations in RAM and internal storage. It uses a 44 pin IDE Disk on Module by default. There are also models with different CPU's from Via C3 to Intel Atoms. Even within the same CPU type, there are different motherboards with different BIOS versions. So if you're interested in one of these, do some proper research! There's a good summary over at ParkyTowers.
Since they all use the same chassis, I made some stickers to be able to tell them apart.
And then I tried to get them to boot MS-DOS. I've seen various guides and YT videos but as mentioned above: there are so many different motherboard variants and BIOS versions. So after HOURS and HOURS of troubleshooting and trying I finally figured out a way to boot MSDOS 7 (Win98 SE) on all models with the internal flash storage. The biggest problem is getting a bootloader onto the flash storage, because the BIOS can't read the old MSDOS boot sector. It would be easier if you had a 44pin-IDE or a SD to 44pin-IDE converter, so you can use modern software to do this. Sadly, I had to try it on the machine itself. I've tried a lot of older software but they all assume you're using a floppy disk to set it up and the HP T5000 doesn't have one. In the end I managed to get it working and here's how it's done in case you're struggling too:
How to install MSDOS 7 onto a HP Thin Client T5000
1. Grab the
The attachment boot98.zip is no longer available
and unpack it.
2. Download 'RMPrepUSB'. I used v. 2.2.4
3. Insert a USB drive and load RMPrepUSB.
4. Set MSDOS BOOTABLE (option #3)
5. Set FAT32 (or FAT16 if you have a <2gb USB) and Boot as HDD (option #4)
6. In Option #5 tick the box and select the folder where you unpacked boot98.zip.
7. Click #6 Prepare MBR Drive. Say YES to the prompt and wait for it to be finished.
9. Insert your USB drive into the T5000 and press F10 for BIOS
10. In the BIOS, make sure USB is boot device #1.
11. Restart and boot into MSDOS.
12. Launch PART.EXE. Press F5 to change to the internal storage.
13. Select any existing partitions and press DELETE. Press F2 to save changes.
14. Press INS and create a new Fat16 DOS (or Fat32 Windows) partition in slot #1. Set Active to YES.
15. Press I to install a Boot Manager onto partition #1. Set number of running dots to 1. Press ENTER until the window is gone.
16. Press F2 to save. Then ESC to exit.
17. Keep the USB drive inserted and restart the system.
18. Run FORMAT.COM D: (if this gives you errors add the /U parameter).
19. Run SYS.COM C:\ D:\ .
20. Your internal flash is now MSDOS bootable!
All drivers for USB, LAN and Soundblaster emulation can be found in the
The attachment DRIVERS.zip is no longer available
Soundblaster emulation is really good (compared to many other TSRs) and IPX works without any issues. So now that I have them up and running, what to do with them? Let's create a luggable retro battle station!
I picked up two ACER V173 monitors for next to nothing. They have 100mm VESA mounts that can hold these L-brackets I got at the hardware store. The T5000 comes on a stand with mounting holes. They are 105mm apart but the holes in the L-brackets are just wide enough to bolt them to the back of the monitor.
I want the entire system to work with just one power cable, so I designed and 3D printed this Y-splitter. You can of course buy Y-split cables but I had plenty of C13 cables laying around to cut up and I needed a good excuse to use the 3D printer again, 🤣. Organised it all neatly with ferrules and wire connectors and a snugly fitting cap for safety.
There is some space between the T5000 and the monitor to store the keyboard. I attached the PSU with some velcro and organised the cables. All done!
Now it's just pick up, deploy and play! The T5000 has an internal stereo speaker, so you'll need no speaker or headphones for this setup.
Since I had plenty of hardware laying around, I made three of these setups! The middle one uses a Benq FP731 monitor.
It's really cool to see them all up and running after all this effort. I've still got a few ideas for improvements:
- Design and 3d print a mouse holder and mount it to the back.
- Find a usb powered (0.5 amp) mini network switch that I can mount to one of the setups.
- Swap internal storage with a larger SD card
More ideas and comments are appreciated! 😁
Visit my YT Channel!
Reply 1 of 9, by Thandor
Nice bro! 👊
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 2 of 9, by TheIpex
Very nifty! It's always great to see these thin clients get a second chance at life.
Intel 486DX2 66MHz
Intel Pentium MMX 233MHz
Intel Pentium III-S 1400MHz
Reply 3 of 9, by Hezus
Made some upgrades to the systems!
First, I really wanted to have a place to mount the mouse, so I designed this mouse holder:
As you can see, there is some space between the backplate and the clip so the material can expand a little. This way it keeps a tight grip on the mouse.
The setup is already quite crowded, so the only real viable place to mount it was on the top. I can still slide in the keyboard from the side, so it works just fine. It's held there quite well with some velcro.
I got my hands on another T5700 and ACER V173 monitor, so I've put together a fourth system. This will be the main unit as it sports the network switch. The switch is a 5 port 100mbit from Renkforce and they're one of the very few that is USB-powered. This one is very slim and even works well on old 0.5 amp USB. I've velcro'd it to the bottom of the unit.
Last thing I would like to tackle is the storage. Already got some stuff for it in the works but I need to wait for a few more parts to arrive 😀 more updates soon!
STL files for the mouseholder and the y-splitter for C13 cables can be found in the attachment!
Reply 4 of 9, by marxveix
I had speed issue problems with Duke3D and slowest T5300 machine and i had 0 boot problems with win95b and its ms-dos.
It has newer Rage XL PCI (4752) that has huge compability issues with 3dcif driver, but D3D and OpenGL works well at Win9x.
This fixed Duke3D speed.
Duke07 - another MS-DOS port of Duke3D
Has similar XL PCI 4752 inside.
Chinese Rage XL PCI mods, improved compatibility and looking for a good overclock.
Collected OpenGL pack and other Rage Win9x files, use ATI2DRAE or ATI2DRAB drivers, some more latest 4.11/all 4.12/4.13 drivers work.
MACXW4 or ATI2DDAD drivers do not work with Rage XL PCI (4752). Eraliest drivers that should work are 2601 and inf edited 4.11.2055.
Win9x OpenGL files:
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … GL-Win9x.7z?w=1
More Win9x Rage stuff:
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … re%20bundle?w=1
Win9x Drivers
https://disk.yandex.ru/d/eV600jDAliJ_3w/Win9x … 64_Rage_PRO?w=1
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
Reply 5 of 9, by onethirdxcubed
Here's an easier way to get the internal Dom formatted properly for DOS with a USB stick, from Parkytowers: TinyCore Windows 98 Install Image
Just don't put any windows 98 install files in the Win98 folder. Or do if you have a larger storage, but these thin clients don't seem to support DMA so it's a subpar Windows experience.
Also you should use PS/2 for keyboard and mouse for the models that have a PS/2 port because legacy USB really saps performance. You can use a splitter cable to get both keyboard and mouse connected. Depending on which splitter cable you get you may have to plug the keyboard into the mouse connector and vice versa to get it to work. There is also a setting in the BIOS for PS/2 port is keyboard or mouse and you may have to switch that.
There is a better FM TSR and sound init tool from Oerg866: Here
Reply 6 of 9, by Hezus
onethirdxcubed wrote on 2025-12-12, 17:05:
Here's an easier way to get the internal Dom formatted properly for DOS with a USB stick, from Parkytowers: TinyCore Windows 98 […]
I'm not a Linux user so I never considered that route to booting the thin client but the Parkytowers tool surely makes it easier. I'll be sure to give that one a try once I get larger drives in them.
Out of my models, only the T5515 seems to have a PS/2 port. The 5700 and 5300 only use USB so I'm limited to that. I think the CPUs are powerful enough to dealt with the overhead for the games I intend to run.
I'm certainly interested in that soundblaster emu TSR. The stock via driver does very well on the T5700/T5300 but I did run into some issues on the T5515. Doom would for instance hang on load with adlib music enabled and not even load if the blaster IRQ was set to 5. Being a older motherboard it probably has an older revision of the VIA sound chip. Maybe these newer drivers will fix that. Thanks for the suggestion!
marxveix wrote on 2025-12-12, 11:14:
I had speed issue problems with Duke3D and slowest T5300 machine and i had 0 boot problems with win95b and its ms-dos. It has ne […]
Win9x OpenGL files:
Win9x Drivers
Thanks for all the links! Very helpful once I get the larger drives in them.
Reply 7 of 9, by doshea
Hezus wrote on 2025-11-28, 13:42:
I'm curious about this, as I haven't had any issues with my t5720, although I suppose it could have a significantly different BIOS. Although I've only booted FreeDOS from the internal Disk-On-Module, I can boot MS-DOS 6.22 from a USB flash drive (it's slow but convenient!).
Do you have any references online describing this issue in any more detail? parkytowers didn't seem to mention anything about this.
What I did have trouble with as always was drive geometry, but in this case it was particularly bad because for smaller USB devices (I think I tried 2GB and 8GB), the BIOS came up with some stupid geometry with 20 heads or something, which DOS doesn't support. For 16GB and 32GB flash drives it came up with sensible geometry, but then for 64GB and beyond it simply wouldn't recognise them.
I found a USB floppy drive useful here. The nice thing about a USB floppy drive vs. a USB flash drive is floppy disks have an actual, physical geometry, so unless the BIOS is really stupid, it shouldn't be difficult to boot from them. Perhaps there is a market for a USB floppy drive emulator! USB ODE should be able to do this with some work.
Reply 8 of 9, by marxveix
I have used laptop cd/dvd with caddy, no extra power needed. Startup disk is on the cd and it detects cd drive with it and it has win9x install there.
Reply 9 of 9, by The Serpent Rider
doshea wrote on 2026-01-02, 01:26:
T5720 is a regular Athlon XP. Transmeta is not x86 natively, so it has a lot of weird quirks associated with it. Like not being able to utilize FastVid to increase VESA performance. Although FreeDOS works just fine on Transmeta. I tested it both on T5515 and T5700.
These clients are more of a curiosity than being really practical, but HP T5515/T5710 have onboard Radeon 7000 and quite capable for early Win9x stuff.
