CD-ROM drive recommendations
First post, by DustyShinigami
So I have a Creative 5233E, and the one draw to it is that it has S/PDIF capabilities so I can play games with redbook audio. However, the big drawback with it is that it's 52x and it's bloody loud! It's like a plane taking off down a runway! I've been using CDSlow in Windows and CDBQ in DOS, though ideally, I could do with having it as a backup drive for the S/PDIF, move it into the lower bay, and have something more period accurate and appropriate. I was hoping for some recommendations on good CD-ROM drives for both Windows and DOS games. What's considered an ideal speed? An ideal make/model? Is there anything else I'd need to consider? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 40, by RetroPCCupboard
I think 4x speed is the sweet spot if you don't want noise. Though I have mine in a Pentium MMX machine. So don't really need faster than that. 4x is the minimum for some early FMV games like Wing Commander Prophecy (1997)
Reply 2 of 40, by DustyShinigami
RetroPCCupboard wrote on 2025-12-15, 22:48:
Wow. As low as that? I was expecting something like 12x to 24x. ^^;
OS: Windows 98 SE
Reply 4 of 40, by DustyShinigami
theelf wrote on 2025-12-15, 23:15:
Hmm. Intriguing. But what puts me off that is the fact it's black. Definitely prefer beige. Otherwise it's not going to match the rest of the system. ^^; Or, is there a beige model?
OS: Windows 98 SE
Reply 5 of 40, by theelf
DustyShinigami wrote on 2025-12-15, 23:41:
Yes, i hate black, but painted and end of problems
The exact old PC color is RAL 7044 Grigio Seta
Believe Me, even if I put my ear next to the cd rom reading at max speed, I CANT HEAR!! my mitsumi 1x do more noise.... crazy
Reply 6 of 40, by DustyShinigami
theelf wrote on 2025-12-15, 23:46:
Yes, i hate black, but painted and end of problems […]
I see. I did not know that. I’ve just used the term ‘beige’ when searching for specific colours. It’s also an option when doing eBay searches. 😅 And they’re only beige due to yellowing with age.
I can’t really find that model on eBay UK from what I’ve seen. Though there are similar models.
Painting… hmm. I don’t fancy buying a specific paint just for a CD drive though. 😅
OS: Windows 98 SE
Reply 8 of 40, by DustyShinigami
Shponglefan wrote on 2025-12-16, 00:59:
I use Mitsumi drives with speeds ranging from 4x to 8x. Quiet and period correct for 90s stuff.
Great. Thanks for the suggestions. I'll see what I can find. 😀
OS: Windows 98 SE
Reply 9 of 40, by NeoG_
8x would be ideal for you I think, but since the market was moving so fast I don't think there is a lot of them around. My creative drive running at 8x isn't silent, and I don't think you even want a compeltely silent drive. Hearing it a bit in the background is OK just as long as it's not like a plane taking off.
Reply 10 of 40, by DustyShinigami
NeoG_ wrote on 2025-12-16, 09:22:
Right. I’ll set my current drive, with CDSlow and CDBQ, to 8x and see what that’s like. But yeah, I’ve only seen one Mitsumi on eBay so far and that’s about £55.
OS: Windows 98 SE
Reply 11 of 40, by DustyShinigami
Ahh. Sadly, there doesn't appear to be much on eBay UK from what I'm seeing. Particularly for 8x.
OS: Windows 98 SE
Reply 12 of 40, by DustyShinigami
Come across a Mitsumi CRMC-FX400D. I believe this is 4x...? From 1995, too. Would this be worth picking up?
OS: Windows 98 SE
Reply 14 of 40, by DustyShinigami
£50...? I've only seen one other similar that sold for about £55.
OS: Windows 98 SE
Reply 17 of 40, by MikeSG
I have a FX400D and it does actually read newly burnt Verbatim CD-Rs. The original poster must have a bad drive or bad CDs...
Reply 18 of 40, by DustyShinigami
Shponglefan wrote on 2026-02-08, 02:07:
That seems a bit on the expensive side for one of those drives. Though if it is in good condition and functional, I suppose it might be worth it.
Yeah, I suppose. But aren't they slightly sought after? As a retro CD-ROM drive, I mean? Mitsumi makes, specifically?
Another one has been found, which is 8x from 1997. For some reason it's listed as new, which I don't think it is. That's £45.60 with free shipping from Denmark. The seller has sent an offer of 10% off, so it's £34.20. That's an FX820S model.
There's another from Italy, which is £30.52. That's model CRMC-FX800S. It hasn't been tested though. The other one has.
OS: Windows 98 SE
Reply 19 of 40, by DustyShinigami
ott wrote on 2026-02-08, 03:40:
DustyShinigami wrote on 2026-02-07, 22:49:
FX400D doesn't read some CD-Rs, I'd look for FX400E or FX400G
Differences between Mitsumi FX400 versions
Thanks for the list. 😀 A couple of new ones I've mentioned are FX800, but I'll check that and compare.
OS: Windows 98 SE
