First post, by vico
Sometimes (mostly) when I try to shut down or restart my PC, it stays at "Please wait while your computer shuts down" and I have to force it to shut down and the next startup it runs Scandisk.
What can I do to fix this incorrect shutdown?
My Specs:
Motherboard: Soyo SY-6VBA133
Processor: Pentium II - 300MHz
Ram: 512MB (Although only half is recognized)
Video card: 3dfx Voodoo3 3000
Sound Card: CT4500 / AWE64 / PnP
OS: Windows 95 OSR2.5
Reply 1 of 8, by Linoleum
Any USB devices installed? Or virtual CD emulators running?
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX4 100, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 2 of 8, by Harry Potter
I'm sorry I can't help, but I've been having the same problem with my Win98SE tower at my mother's house. 🙁 Maybe it's a problem with a DOS driver?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 3 of 8, by Joakim
Used to have this back in the day. I always figured it has to so with hardware changes. I usually reinstalled windows when it happened. Would be nice with a cleaner solution though!
Reply 4 of 8, by dukeofurl
This happens to me with my windows 98 pentium 1 PC. Generally if I tap the esc key a few times that seems to make it continue to the you can now shut down your PC message.
Reply 5 of 8, by vico
Linoleum wrote on 2025-12-18, 22:15:
I have a VIA card with 5 USB ports and I use Daemon Tools 3.47
Reply 6 of 8, by Linoleum
vico wrote on 2025-12-19, 16:35:
Deamon Tool was the worst for me and was hanging the shutdown process on all my machines... Just for sanity sake, did you try without the VIA card installed?
Reply 7 of 8, by dukeofurl
Oh interesting, come to think of it I have daemon tools installed as well!
Reply 8 of 8, by Linoleum
dukeofurl wrote on 2025-12-19, 20:48:
I should add that sometimes Daemon Tools itself was the culprit, and other times it was the required USB driver package causing the issue. Ever since I switched to XUSBSUPP for USB support on Windows 95, I haven’t run into any problems.
