First post, by Guest
If I use audio pack from www.glidos.com/audio.html I know that only 3 first levels are fully done. But my question is: will I have ambient sounds for all levels? It says "but for all levels the process has gotten as far as restoring the background ambient sounds". Is that what it means that all the levels have at least the ambient sounds?
Also does Glidos use sounds and music from the TR1 CD at all? If so why the need for Audio Pack?
