First post, by JShone2025
Hi folks. I've been an XT and AT/X PC user and collector for many decades and my latest score is a Mitsubishi 286, built in the first quarter of 1987. It came with an EGA card and an MFM controller. I've removed both and now want to boot from a CF card just like in the video by JTech95 on YouTube. He doesn't use XTIDE at present, just an IDE card, booting with a 5.25 DOS boot disk first
I have....
Installed a 16 bit Goldstar IDE/FDD controller
Installed a 16 bit NIC card with XT IDE boot ROM
Installed a CF to IDE adapter in slave mode (32Mb)
Left the 5.25 drive plugged into the system board
The computer starts and gives the obligatory 'F1 to continue' BIOS config prompt. Then XTIDE kicks in and detects nothing at Master..once it gets to Slave the computer often locks up. If the CF card is removed it cycles the entire XTIDE process without locking up.
The CF card is formatted and MBRd with DOS 5.0
It will boot on an an Aladdin GA-5AX board (that I have had nearly 30 years). The CF card was prepared on the GA-5AX board, not with the 286. There does not currently seem to be a way of booting to a DOS floppy until I take delivery of a 5.25 boot disk from the USA. I wiped my last one accidentally.
I am unsure whether the CF card is industrially rated also, so I've ordered others for trying out.
Please help if you can, as I think this PC is an awesome piece of history (maybe that opinion is overblown due to me being only 3 years old when it was new - but I digress!). I think my two 1988 vintage Deskpro 20e PCs in the collection are so much more easy to work on by the way..
I wouldn't have the slightest idea how to reconfigure XTIDE. Also I still need to try the supposed boot disk that will access the BIOS, though this PC seems not to have a hot key accessible one, only dip switches at the front panel.
The attachment IMG_20251223_223545198_HDR.jpg is no longer available
The attachment IMG_20251223_223533166_HDR.jpg is no longer available
The attachment IMG_20251223_223523826_HDR.jpg is no longer available
The attachment IMG_20251223_223513702_HDR.jpg is no longer available
The attachment IMG_20251223_223438027_HDR.jpg is no longer available
Thanks in advance.
Reply 1 of 25, by douglar
Quick check- Do you have the master slave jumper set correctly on your CF adapter? Is the #1 pin of the cf adapter lined up with the #1 pin on your IDE card?
I have had some difficulties with CF adaptors that look like the one you have there, female socket, minimal components on board, no voltage selection. Any chance you have another 40 pin cf adapter?
Reply 2 of 25, by konc
Why is they CF set as slave? Because of some quirk of this specific PC or is it arbitrary? I'm asking because not all adapters and cards behave well as slave. Especially when, if I understood correctly, there is no master present.
Reply 3 of 25, by JShone2025
konc wrote on 2025-12-24, 12:48:
It does the same thing set to master. I will try another CF card adapter once it arrives in the mail. I don't have any good hard drives to try with it at the moment. Ones I've plugged in that did show some life produced garbled characters when detected and then the screen froze as usual.
Reply 4 of 25, by JShone2025
douglar wrote on 2025-12-24, 12:31:
I would have to borrow a HDD out of one of my sub 1gb systems if I'm desperate to get answers...but I think you're right - I can't personally be sure it is plugged the correct way round or vouch for the quality of the CF adapter. I don't want to rip apart other computers for the sake of this one, so I will wait on a new CF adapter and CF card plus 5.25 dos boot disk.
Reply 5 of 25, by JShone2025
Ok, the activity light stays on until the CF card channel is detected (and HDD light on the IDE card). Think this may be a boot sector issue with the CF possibly. Will report back.
Reply 6 of 25, by douglar
JShone2025 wrote on 2025-12-24, 15:27:
First run the cf as a master. Too many CF’s out there don’t like being slave. Get that out of the way.
Next, the garbled characters in the device name usually indicate an electical signal problem of some sort. Data is not transmitted reliably between the cpu and the cf. If you Bios has an isa speed divisor, make sure it is set so that your bus is running <9Mhz. Then clean the edge connector & ide pins on the IDE card. A swab with isopropyl alcohol or a pencil eraser usually work well for this. You could also try a different isa slot or try inserting and removing the card a couple times if the slots look dusty or dirty. Or maybe there’s some other card in the system that’s misbehaving and talking on the bus when the ide controller tries to talk.
But my money is that the CF adapter is defective. I bought a pair that looked like that this fall and neither worked reliably. My adapters worked well enough to detect the devices and booting Dos, but if I tried to install win95, things would fail during the install or the files system would become corrupted shortly afterwards on the times that the OS installed successfully. I was doing UDMA speeds though.
Reply 7 of 25, by JShone2025
douglar wrote on 2025-12-25, 00:46:
First run the cf as a master. Too many CF’s out there don’t like being slave. Get that out of the way. […]
Thanks. I've messed around enough. I've ordered an SD to IDE adapter for good measure and also a Glitchworks XTIDE. Let you know how it goes!
Reply 8 of 25, by jmarsh
An SD to IDE adapter is going to be worse; they are just SD to CF adapters wired to an IDE connecter.
Reply 9 of 25, by douglar
jmarsh wrote on 2025-12-25, 16:45:
Not sure what you are getting at there. Pata is pata, regardless of whether it is on 40 pins, 44 pins or 50 pins like a CF.
The sintechi SD to Pata bridges have some incompatibilities, but I don’t think they will figure into this build.
A CF to 40 pin device is an adapter because it just reroutes wires. SD to Pata is a bridge because it has to translate protocols. That’s more complicated, but there is only one family of chips & and few firmware versions used in these devices so they are a little more predictable that cf devices that have dozens and dozens of flash controllers and even more firmware versions.
Reply 10 of 25, by jmarsh
douglar wrote on 2025-12-25, 16:48:
And they're rubbish. They have a lot more incompatibilities than regular CF cards running in IDE mode. They can't even get the C/H/S translation right unless the card has a FAT primary partition already present to take values from.
(Not to mention the speed of them is also absolute garbage compared to regular CF cards.)
Reply 11 of 25, by douglar
jmarsh wrote on 2025-12-25, 18:39:
You seem to have some strong opinions here.
My benchmarking shows that when paired with a non crap SD card, a SD bridge will perform similarly to the fastest CF devices on controllers up to ATA 33. When you get to ATA 66 and better , the top performing CF devices start to pull ahead, but the top performing group of CF devices is a pretty small subset of CFs.
But these are just generalizations. On older controllers, there are a lot of variables that come into play when looking at storage performance, so a storage device that performs well on one system might appear slow on another,especially when just doing things faster than PIO on a 16 bit ISA bus.
While sintechi SD bridges have quirks and issues, one SD sintechi bridge is pretty much like all the others so they all have the same quirks and issues. They have some predictability.
CF devices on the other hand were under active development by many vendors for many years, so predicting what quirks your device might have can be more challenging and the performance & compatibility varies a lot from a y2k silicon drive to a 2015 industrial ultra to a 2008 card design optimized for cam corder storage.
This post shows some of the variability I saw on a VLB bus.
Re: List of VLB IDE Controllers
Much narrower range of performance when you are limited to PIO 0 on an ISA bus. Pretty much all solid state storage is going to perform about the same.
Reply 12 of 25, by douglar
After talking about this, I reviewed the sketchy CF adapters out of curiosity to see if I could spot what went wrong. Looks like the 50 pin connector was fragile. One of the CF's I used must have had some resistance on the last pin and it pushed pin #2 down in the in connector and caused it to bulge out on the bottom by the solder. I pushed it back, but I don't have a lot of hope for the longevity of these devices. Once they get bent like that, it's never as strong again. That's one of the signal pins, so yeah, a weak connection could cause the problems I saw.
The attachment Photo Dec 26 2025, 2 59 24 PM.jpg is no longer available
Reply 13 of 25, by JShone2025
douglar wrote on 2025-12-26, 20:13:
After talking about this, I reviewed the sketchy CF adapters out of curiosity to see if I could spot what went wrong. Looks like the 50 pin connector was fragile. One of the CF's I used must have had some resistance on the last pin and it pushed the pin down in the in connector and caused it to bulge out on the bottom. I pushed it back, but I don't have a lot of hope for the longevity of these devices. Once they get bent like that, it's never as strong again.
I'll look out for that quirk. I did try the plate mounted CF adapter yesterday with different IDE cables. Red LED and HDD led powered off the IDE card is on constantly when the PC is powered on. There is still no drives showing up by descriptive means as detected. This is so - except for a pause where the HDD activity light and faceplate red LED also extinguishes during polling relative to it being jumpered for slave or master respectively.
I'm going to see what booting off A: does in the XTIDE boot menu once I get hold of a DOS 6.22 boot disk. I don't hold out much hope FDISK will see the HDD if the XTIDE network card BIOS doesn't list it in the first place however.
I am also waiting on a good usable 5.22 floppy to put drive overlay software on so I could boot from that with and without XTIDE to see what results I get for HDD drive visibility.
I could always buy an MFM hard disk though and it would be job done 😅
Reply 14 of 25, by douglar
JShone2025 wrote on 2025-12-26, 20:27:
As long as the device detection shows garbage characters in the device name, it's very unlikely that you will be able to transmit or retrieve uncorrupted data from the device. The signals are not getting through accurately.
Reply 15 of 25, by JShone2025
douglar wrote on 2025-12-26, 21:08:
Without XTIDE and just the Goldstar IDE card I managed to get a blinking cursor and no further activity, so eliminating the NIC card and booting plain vanilla from a floppy might be worth a try to then use FDISK.
I never knew this would end up being so difficult. 386 in all flavours really are a much superior beast!
Reply 16 of 25, by JShone2025
This now works as I got a Glitchworks XTIDE. Still get a CMOS checksum error. There is a Sperry DOS 3.1 diagnostic disk pack on eBay but it's too expensive to risk really and there's no returns. I'm very pleased with how it's turning out now. Can only see the 5.25 drive contents but not read them however but I have a CDROM and flash card now.
Reply 17 of 25, by JShone2025
I de-scuffed, cleaned and bleached the whole unit exterior too!
The attachment Messenger_creation_A49973D2-8A99-4C45-A9A2-54AEA3D86C5A~2.jpeg is no longer available
Reply 18 of 25, by douglar
JShone2025 wrote on 2026-02-05, 12:25:
Looks very nice! Did you just use straight up chlorine bleach or something more exotic like peroxide or an oxy cleaner?
Reply 19 of 25, by JShone2025
Thanks. I used peroxide hair bleach and two UV lamps over 24 hours and kept rotating the plastic bezel. Half of the time I masked off the Mitsubishi logo and did not apply cream to it. The 5.25 drive was done very carefully in situ . I am going to sand off the 52x print on the CD drive when I get a moment.
