First post, by kolmio
I have a late black AT desktop case with just one 5.25 bay. Now it hosts CD ROM drive from original build - one with 2 buttons: play and eject.
I'd love to have some DVD drive to be there, or at least CD RW. But most of BLACK drives out there lack Play button, so it would mean functionality loss.
Are there a good chance to find DVD drive with play button?
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 1 of 4, by Disruptor
Well, I could define 3 levels:
Level 1) Find a drive with headphone connector
Level 2) That drive should have a play button
Level 3) The interface should be SATA
While I never found a level 3 drive there may exist some level 2 ones like kolmio has posted.
Reply 2 of 4, by Ozzuneoj
I would be surprised if there were any SATA drives that also had a play button. The number of people plugging headphones into their CD-ROM drive and playing it without using the rest of the computer had to be incredibly small by the year 2000, let alone 5-6 years later when SATA drives became more common. Also, IDE at least allowed the possibility of using the straight analog audio out of the drive (which you could use the play button for), but I don't believe analog audio output was was a thing on SATA drives at all. If someone knows of a SATA drive with analog audio out though, please post it. I am curious. 😁
(EDIT: Looks like someone successfully modded an analog output to a SATA drive that still had a place for one on the PCB. So, I guess it is maaaybe possible that some SATA drive that uses a similar older style PCB might have also used an older housing that had a play button too.)
Likewise, PCs with black\dark drives weren't common at all until around ~2001 with some OEM models like the Dell Dimension 4200 and others getting the ball rolling.
So, you're looking for a drive that uses kind of an outdated design\housing that still has the play button and headphone jack but was made at a time when it was likely to be used in a black PC... and before they were SATA. Maybe looking at some old PC catalogs from 2001-2004 will give you some brands and models to look for?
EDIT: Aha! I searched for Black 16x DVD IDE drives and found this Dell 0D7191 that has two buttons and a headphone jack on the front:
https://ithardwarehub.com/part-no-0d7191-dell … vd-drive-black/
They seem fairly uncommon, but hey, it's something to look for! Also, it isn't a burner... it is just a CD\DVD reader.
... also, what happens when you have a DVD in the drive and press play in Windows? Does it actually make Windows open up the DVD player? Never thought about this before. 😋
Reply 3 of 4, by jmarsh
Ozzuneoj wrote on 2025-12-27, 17:34:
The fact that they still included a DAC (digital to audio converter) inside the drive even though it didn't have an analog output port still baffles me. Surely that would have cost more than the audio cable socket.
Reply 4 of 4, by kolmio
Wow, thanks, that's giving some hope.
Regarding what you asked - I think nothing should happen, because the button made the drive play Audio CD, not Windows to launch a player. Drive could do that without motherboard at all.
