First post, by damoton
- Newbie
The pc version of skylanders spyros adventure runs normally at a steady 60 fps at all times, but with dgvoodoo it suffers from frame drops and can dip to as low as 17 fps.
This is without any changes in config, just adding the required files in the game directory (exe, config & ms/x86 files).
The game lacks any AA so I want to use dgvoodoo to implement either MSAA or SSAA into the game. Both methods work and look good ingame, so I want to use dgvoodoo but without the slowdown.
I've tried to fix it by tinkering with the config, but to no avail. I have looked at other methods of implementing AA but haven't found anything besides dgvoodoo that actually works.
Any solutions?
