First post, by Ozzuneoj
- l33t
I'm sure the number of people who still have these is getting pretty low, but I have had mine for 20 years and I am just now reading about this...
https://consolemods.org/wiki/CRT:Diamondtron_ … Unlocking_Guide
I will just quote the page here for posterity:
Diamondtron SB VSync & HSync Unlocking Guide Overclocking Tutorial […]
Overclocking TutorialDiamondtron HSync & VSync Unlocking Tutorial (NOTE: Only works on 22" SB monitors):
Turn off the monitor.
Turn on the monitor while holding the EXIT button until you see a raster image then release and press EXIT again and you will see the FACT DATA menu.
Press the (-) button once to set the data value to 255 then press the (+) button to set the data value to 5 then press the SELECT button.
Navigate to the right in the OSD menu until you find the FACT DATA menu again.
Press the (+) button until the DATA value is set to 99 then press the SELECT button.
Press either the (◀) or (▶) buttons and you will be introduced to the FACT DATA-E2P menu.
Cycle through ADDR to change DATA values:
Change DATA Decimal in ADDR 004 to adjust the HSync Minimum +1 (31 is 30KHz)
Change DATA Decimal in ADDR 005 to adjust the HSync Maximum +1 (141 is 140KHz)
Change DATA Decimal in ADDR 006 to adjust the VSync Minimum +1 (49 is 48Hz)
Change DATA Decimal in ADDR 007 to adjust the VSync Maximum +1 (161 is 160Hz)
Press the EXIT button after each ADDR modification to save each address value then enter the FACT DATA-E2P menu again to change other ADDR values.
Exit the OSD.Notes
This tutorial only applies for 22" Diamondtron SB monitors (and their rebadges) such as the 230SB and 2070SB.
The maximum known limit for the VSync and HSync are 254Hz and 152Khz respectively.
This tutorial does not need any additional equipment unlike Sony's WinDAS.
On my HP P1230 (rebadged Diamond Pro 2070SB) I was able to access this menu easily using these instructions. On mine, ADDR 004 (Hsync Minimum) is set to 29, which would apparently be 28Khz? Seems like an odd choice, but that's what it is.
I am able to change the value, but... I don't have the nerve to save it. I've had this thing forever and it works perfectly. It is basically the holy grail of 4:3 displays aside from its size and weight. To say that I'd be upset if I broke it would be an understatement.
Has anyone ever used this method to successfully get these monitors working with 15khz signals? What would be the reasoning behind not allowing these signals in the first place? Surely there has to be some downside to having this setting that low?
