First post, by FreddyV
Hi,
General MIDI rendering is in Progress for the PicoMEM 2.
As well as PS1 Audio (Will be for the actual PicoMEM as well)
Plus GUS
It should be a little Step ahead PicoGUS in Audio 😉
PicoMEM General MIDI:
The attachment E1M1_Pitch.mp3 is no longer available
PicoMEM GUS (Recorded in MONO but is Stereo):
The attachment Solstice_PicoMEM_GUS_Mono.mp3 is no longer available
Reply 1 of 15, by carlostex
That's very interesting Freddy. I would find it much more interesting if the PicoMEM 2 would just simply have an intelligent MPU-401 interface instead of just some generic General MIDI. That and with all the audio options you are adding the PicoMEM is gonna be a one for all sound card.
PicoMEM: Sound Card Edition 😀
Reply 2 of 15, by Linoleum
My PS/2 Model 30/286 is begging for the PicoMem2. Now if only you could bless us with an MCA version for my Model 55… One can dream. 😉
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 3 of 15, by FreddyV
Linoleum wrote on 2026-01-16, 03:37:
Nope 😀
Reply 4 of 15, by NeoG_
FreddyV wrote on 2026-01-15, 16:45:
Hi Freddy, do you have a target feature set for the public release of the PicoMEM2? Any chance of Fluidsynth/Generaluse GS soundfont or MUNT instance? There is nowhere on the PicoMEM2 board to plug in my WP32 McCake 🙁
Reply 5 of 15, by carlostex
NeoG_ wrote on 2026-02-06, 01:06:
Pico 2 is not even close to be powerful enough for MUNT, so in that case I also wish that Freddy would include wavetable header with MPU-401. Perfect to use a wave blaster Pi, or a dedicated classic General MIDI wavetable DB.
Reply 6 of 15, by FreddyV
carlostex wrote on 2026-02-06, 01:46:
Hi,
PicoMEM should support USB MIDI adapter, be patient 😀
I don't want to transform the PicoMEM to a PicoGUS even if it PicoMEM 2 will be almost like PicoGUS
Also, the General MIDI implementation is done using .SF2 file
I still have to improve the code to be able to change the SF2 and support big ones (Here it is 4Mb)
Reply 7 of 15, by FreddyV
Hi,
What the PicoMEM can do in General midi is quite nice already.
I prefer to challenge myself to do thing than take the simple path and just plug an external MIDI device 😀
I still have to think about what I want to have ready for the Release.
Normally, I want to have GUS and Sound Blaster totally Ready, and finish code to implement the boards hardware differences
CD Emulation as well, I think for later
Reply 8 of 15, by Shreddoc
FreddyV wrote on 2026-02-06, 21:34:
Hi, […]
Hi,
Ahh, .SF2 support! That is cool!
I wonder what approximate SF2 size might be possible in future, with this hardware.
Reply 9 of 15, by carlostex
Hi, […]
Hi,
I understand. I just think its a lost opportunity, would be cool for it to be a one card solution, which would be specially important for systems that only have 1 or 2 ISA slots. Also SF2 won't cover the uniqueness of some dedicated daughterboards, like with Yamaha XG. I mean if it's gonna have GUS and SB...might as well have MPU-401 and header.
Reply 10 of 15, by NeilKnows
PicoMEM v1 already works great in these machines...
Reply 11 of 15, by Linoleum
carlostex wrote on 2026-02-07, 09:28:
Hi, […]
Hi,
Since PicoMem includes a USB port, we can probably just use a USB‑to‑MIDI adapter for whatever device you prefer. A dedicated MIDI header would take up quite a bit of real estate on the card anyway.
PS2 30/286, SBP
Reply 12 of 15, by Kekkula
My niche user case would be my euro-pc 1. It only has one isa card slot.
Picomem with wavetable header / mpu401 midi port, would be perfect one card solution.
One could get ram expansion from 512k to 640, sd card hard drive and mt-32 sound from various mt32pi projects.
Reply 13 of 15, by carlostex
Linoleum wrote on 2026-02-07, 13:53:
Sure but that would require another device to host a DB, and then power that device etc...
Well, this is Freddy's project and it's up to him. I just thought if doing GUS and SB, you might as well. Would be a perfect one card solution to people with limited number of ISA slots, and compact systems.
Reply 14 of 15, by digger
I’ve had the idea of some kind of “smart” USB add-on card for vintage hardware that you could just plug multiple modern USB devices into, possibly through a USB hub, and then the card would present the connected USB devices to the host system as native legacy devices, negating the need to implement a USB stack for DOS and drivers and emulators and such.
So plug in a USB MIDI adapter, and the card would present it as an MPU-401 MIDI controller to the host systems, preferably with support for Intelligent Mode as well as UART mode. Plug in a USB sound device and the card would present it to the host system as a Sound Blaster compatible sound card. Plug in a USB game controller and the card would present it to the system as a 15-pin PC game port adapter. Plug in a USB mouse and the card would present it to the host PC either as a serial mouse or a bus mouse. Plug in a USB stick or external hard drive, and the system would detect it as an (XT-)IDE device. Wi-Fi dongles would show up as NE2000 network adapters. And so on, and so forth.
I guess the PicoMEM, being a software-defined expansion card, could be made to support all this. A lot of such projects exist for some of these things, but having a single card that could emulate all this, effectively forming a bridge between common USB peripherals and virtual legacy devices that are compatible with hardware that was natively supported back in the DOS era, that would be so incredibly practical.
Of course it might be a challenge for a PicoMEM-like card to support so many hardware IO addresses, multiple IRQ ports and DMA channels simultaneously on a single card with a single RP2040 or RP2350 controller.
Reply 15 of 15, by FreddyV
digger wrote on 2026-02-07, 19:46:
I’ve had the idea of some kind of “smart” USB add-on card for vintage hardware that you could just plug multiple modern USB devi […]
PicoMEM :
Plug a USB Mouse, mouse working
Plus a Jack to the audio : PicoMEM is Tandy, CMS, Mindscape, Covox, Sound Blaster, Gravis
Plug a USB Drive : DOS can see the drive as a network drive, with no limitiation in disk/File size and file system
Plus a Joystick : Work as a PC analog joystick
Wifi is supported
Not sure what you want to do in a different way 😀
