First post, by DeathAdderSF
Hello, all.
To all the audiophiles here who've mastered the art of the ISA sound card:
What would you say are the top picks for recording stereo FM audio from a Sound Blaster Pro (CT-1330) compatible card, via the 3.5mm jack, with the lowest amount of introduced noise? This specifically concerns games where stereo music is only available via dual OPL2.
Would appreciate your thoughts, thanks.
Cruise by Diskman Presents: filled with geektastic classic gaming goodness!
Reply 1 of 11, by carlostex
There aren't many CT1330 clones and I'm not sure any CT1330 clones or compatibles improved much the sound quality output.
Best option I know of, and I own both cards, is the OG Pro Audio Spectrum. The PAS isn't necessarily compatible with the SB Pro 1 and it shouldn't since it predates Creative SB Pro introduction.
However, PAS is supported on probably 99% of games that actually output dual OPL2. I know this isn't the answer you were looking for but it is what it is.
Try to do the best you can with your CT1330, use a good PSU, watch out for ground looping noise, disable or mute everything that is not needed on the CT1330 for the least noise introduction as possible.
Reply 2 of 11, by Grzyb
If you're a true audiophile, then forget about the 3.5mm jack, and go for this - http://yehar.com/blog/wp-content/uploads/2009/09/ads.pdf
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 11, by DeathAdderSF
carlostex wrote on 2026-01-22, 10:59:
I was afraid someone was going to recommend that'n. I sold my 8-bit PAS a few years ago, as it wasn't getting any use. 😔
Reply 4 of 11, by DeathAdderSF
Grzyb wrote on 2026-01-22, 12:16:
Actually I've been using the Adlib-Digisnap for years; I even host a website where I share my efforts: Ad Lib music archive.
Problem is, it only supports recording from a single YM3812 chip. To record stereo Ad Lib, I'd need to record each song twice, then splice 'em together. It's not the time investment or the headache I'm concerned with. Rather it's that I'm not keen about having any timing differences, even tiny ones, from this process. Shame there ain't a stereo Digisnap, but I'm grateful for what I have just the same.
Reply 5 of 11, by DeathAdderSF
As an aside (switching gears for a second): Where the PAS-16 is concerned, is there one particular revision that provides the cleanest sound, or do they all basically offer the same quality level?
Reply 6 of 11, by carlostex
DeathAdderSF wrote on 2026-01-22, 21:03:
You've sold the PAS and kept a CT1330? Damn... If i had to choose the CT1330 would be gone in a second
Reply 7 of 11, by carlostex
DeathAdderSF wrote on 2026-01-22, 21:08:
I guess so. The PAS 16 models where the S stands for "Studio" instead of "Spectrum" were marketed as having better sound characteristics but do they really? I honestly have no idea.
Reply 8 of 11, by cyclone3d
I've got multiple CT1330 cards, a PAS 8-bit and a couple of the CT1330 clones.
Never even hooked up the clones.
The CT1330s don't seem to be that noisy to me.
The big thing I have noticed in the past is that the "noisy" cards can usually be quieted up a ton by:
1. Having a motherboard that has electrolytic capacitors that aren't faulty.
2. Not having a motherboard that only has tantulum capacitors (extremely noisy on boards like this).
3. Having a power supply that outputs good, clean power. This excludes pretty much every power supply from back then. Always get a good brand that is at least 80+ bronze certified or that got reviews that actual testing was done on and showed very clean power output. The less ripple the better.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 11, by SuperDeadite
These days, I'd recommend using hardware VGM players if you want high-quality low-noise recordings. Personally, I mostly use MSX myself, but there are lots of options for OPL2/3 such as RetroWave or this: https://www.tindie.com/products/denjhang/re2- … 2nd-sound-card/
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 10 of 11, by cyclone3d
SuperDeadite wrote on 2026-01-23, 03:55:
Do any of those support dual OPL2?
YMF7x4 Guide
Reply 11 of 11, by SuperDeadite
cyclone3d wrote on 2026-01-23, 04:33:
Yes, VGM spec fully supports dual chips. With the item I linked, you just need two of them plus a host module with enough slots. It is also very easy to convert dual opl2 to opl3 with the VGM tool set. (It will accurately convert to OPL3 stereo.)
I'm using one of the OPL2 boards here, (MSX as host module)
https://youtu.be/XSHZgw56zl8?si=8FNxSlaot2S4QlVB
