First post, by midgard
Hi all
I can’t seem to find any manual for this case Online.
I bought this case used and it came with some motherboard standoffs but not all of them. When i was trying to line up motherboard with the standoffs ports didn’t line up correctly in the IO-shield. Motherboard was also floating in the air for the screw closest to the IO-shield. Tried a later mobo and same story.
I’m figuring the standoffs might not be the correct size. These that i have measure in at 8mm. I’m thinking the standoffs needs to be 1mm longer for it to fit correctly.
And don’t even know if the ones included are the ones that actually came with the case. Could be warped case as well, hope not.
If someone has this case i would be glad to have the correct measurements of the standoffs. Thanks!
Also any other similar experiences with this case? Alignment could be of from the factory for all i know. Measurement from the bottom plate to the io shield is longer on this one compared to my Enlight case so it should have longer standoffs. That’s all i know.
