First post, by Jackhead
Im running a DOS6.22 system with a P75 CPU.
Anything working just fine so far. But i notice that i got system freezes particular on older Lucas Arts Games, for example Indiana Jones Atalantis or Day of the Tentacle.
Im playing the Games with Midi and SoundBlaster Combo.
When that crash happen, the SB sound crackle a bit and the Midi still playing fine. System freeze than.
First i was thinking its because the fast CPU for that kind of Games. But even with disabled L1, CPU Cache and turbo disabled (cpu bench say 30MHz 386 speed) it keeps crashing.
Any other "non" Lucas Arts games i testet work just fine.
My Sound Card is a CT2230 SB16 load with 220/5/1.
Any idea why Lucas Arts dont like my setup? My start values for Indiana Jones for example: "atlantis s220/5/8 r" (8 is the buffer).
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 3, by Beerfloat
Just in general when something is flaky or marginal, might be good to try disabling L2 cache, or turning off writeback, or setting less aggressive memory timings, or swapping out memory modules, trying different memory slots, making sure ISA bus is not overclocked..
Reply 2 of 3, by NeoG_
If you are using a PS/2 mouse try cutemouse 2.0a4 as your mouse driver
Reply 3 of 3, by Jackhead
Yes I think I'm using 1.9 CT mouse. Would try it today. Looks like that happen only to LUCAS arts talkie versions.
