First post, by J-Tech95
Hi guys! I have been researching different options for 8-bit ISA sound cards to use in my TeleCat-286 build and I was curious what the consensus was on the Game Blaster card?
The attachment Creative_Music_System.jpg is no longer available
I have never seen one in person, but I have heard some sound clips and it sounds pretty good honestly. I already have several AdLib cards (1 real, 2 clones) in some of my other machines, so I wanted to try something different.
Are there any other 8-bit sound cards you would recommend I look into? On a side-note, the prices on these things has gotten worse lately it seems 😛
Thanks!
💾J-Tech95💾
Reply 1 of 10, by cyclone3d
Way easier and probably cheaper to get a Sound Blaster 1.0 or 1.5 and add the CMS chips if they are not already present.
And then you get Adlib and digital sound as well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 10, by Jo22
There are replicas of the CMS..
Just look for "CMS Game Blaster Clone"
More information:
https://forum.vcfed.org/index.php?threads/cre … -replica.47900/
https://forum.vcfed.org/index.php?threads/cre … er-clone.60705/
https://github.com/gemedetpaps/MUS-1099
But ja, getting an 8-Bit Sound Blaster with the CMS chips is fine, too.
Just make sure you have the correct PAL/GAL chips for upgrade (if you need ti upgrade).
In the early years, ca. early 2010s, the files for the PALs had to fit the correct SB2 revision or the FM chip could die.
Loading the right Creative DOS drivers for GameBlaster/CMS vs Sound Blaster is important, too.
Because the Sound Blasters have a logic that allows the SAA chips and the YM3812 to work same time without address conflict.
Reply 3 of 10, by Shponglefan
I have a Game Blaster, but to be honest I haven't used it much.
In my experience the only game that sounds really good with it is Silpheed. Though I suppose that is up to personal opinion.
As mentioned above, there are other options for CMS support besides a dedicated Game Blaster card including replica Sound Blaster cards with CMS support.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 10, by Pickle
id suggest trying out the picogus, affordable and also emulates many sound cards including CMS
Reply 5 of 10, by carlostex
Pickle wrote on 2026-01-27, 15:50:
Before the PicoGUS i would recommend the PicoMEM. It allows to have all the sound card emulations enabled at once without need to constantly reprogram firmware. Also the PicoMEM is still being improved.
Reply 6 of 10, by Matchstick
carlostex wrote on 2026-01-29, 00:19:
PicoGUS doesn't do that anymore, can now change with /mode variable. It is also still being improved. After PicoIDE, Polpo, will be going to PicoGUS v3 using the Pi5 chip.
As far as the CMS, This was the first sound card I owned, cause it was all I could afford, and was sorely disappointed until I got a SB.
Reply 7 of 10, by carlostex
Pi5? Or do you mean the RP2350? Pi 5 CPU is orders of magnitude more powerful than a Pico 1 or even Pico 2
Reply 8 of 10, by matze79
Shponglefan wrote on 2026-01-27, 14:59:
Monkey Island Sounds great on it and it supports Stereo
Reply 9 of 10, by FreddyV
Nope, it is different as there is no need to run a command to move from one card to another.
PicoGUS 3 may be really late as ian is busy with picoide
Picomem 2 will be there in some months with gus, sb, general midi and more. (Tandy, cms, Covox, disney, mindscape, ps1)
The attachment 20260130_175046.jpg is no longer available
Reply 10 of 10, by carlostex
PicoMEM 2 looks awesome, just needs a wavetable header and MPU-401
