First post, by newbie_42
Rank BANNED
BANNED
I installed windows 3.11 and the mouse worked during installation, but when i boot it up, the mouse will not work at all. It stays in the center. Yes i have tried using every core, and yes i have tried crtl+f10, none of it does anything. Any help would be greatly appreciated. 😁
Reply 1 of 5, by Kippesoep
Which version of DOSBox are you using? Also, what mouse driver is selected in the emulated Windows?
My site: Ramblings on mostly tech stuff.
Reply 2 of 5, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Do you use CVS? Did you select PS/2 mouse?
BTW: This belongs to DOSBOX games/Apps
Mirek
Reply 3 of 5, by newbie_42
Rank BANNED
BANNED
The dosbox version im using is 0.63.
Im using the ps/2 driver in win3.11 atlest thats what i selected during installation, when i go to see what list of drivers i have installed it only shows audio drivers... i dont know if im not looking in the right place or what. I'v even tried installing a driver i found on the internet that i was supposedly made for 3.11, but wouldent execute in win 3.11.
No im not using a CVS, as i was very confused about them, and beings that other peoples mouses have worked, i dont see why i need to go out and get a version thats gobbed up full of stuff i dont want anyways...
this is the windows forum, how does this not pertain to my question?!?.
Reply 4 of 5, by gulikoza
The windows forum is for windows w/o dosbox.
Most of the changes in dosbox required by windows to run were made after the 0.63 release. So you really need to use a cvs version if you want to run windows. If you do not like experimental patches, use this version
http://cvscompile.aep-emu.de/dosbox.htm
it is without any patches, just a compiled snapshot of current code.
http://www.si-gamer.net/gulikoza
Reply 5 of 5, by newbie_42
Rank BANNED
BANNED
thanks for the help qulikoza, the newest one worked.
