Acorn Business Computer
First post, by yevrowl
There is a line of PCs that are quite diverse in terms of functionality and even architecture — Acorn Business Computers.
Interested in whether there are emulators for them, as well as interpreters and compilers for the BASIC programming language.
Reply 1 of 4, by yevrowl
Suggested that are emulated using MAME.
Reply 2 of 4, by jtchip
These aren't PCs in the sense of the IBM PC and compatibles discussed in this forum. From the wiki:
The ABC range was developed by Acorn essentially as a repackaged BBC Micro, expanded to 64 KB RAM, to which was added (in some models) a second processor and extra memory to complement the Micro's 6502. The electronics and disk drives were integrated into the monitor housing, with a separate keyboard.
So use any BBC Micro emulator. If you just want to run BBC BASIC, there are ports to various platforms, including modern ones.
Reply 3 of 4, by megatron-uk
Never seen any examples of these, and I'm in the UK and have come across pretty much every type of Acorn/BBC.
Judging by the numbers stated in the article I would doubt if these were actually sold in any number or reached the market beyond a small few. In fact, just reading a little further it seems like none of them were produced other than the 210.
They basically sound like a Model B (more like a Master, minus the extra ram) with a 32016 second CPU. Something that you can actually put together without too much difficulty.
IIRC, there was a Pi based project to use the Pi as a second processor replacement, so it may not even need a genuine 32016 second CPU box tracking down.
https://www.target-earth.net
Reply 4 of 4, by megatron-uk
Yep, here you go:
https://github.com/hoglet67/PiTubeDirect/wiki
Use a Pi to emulate/replace any of the Acorn second CPU interfaces, including the 32016. Add that to a model B and you are probably 99% of the way to one of those Acorn Business Computer models.
