First post, by wbahnassi
- Oldbie
Hi guys,
I'm trying my luck with a stupid HP OEM board. It's the Asus MEW-VM (https://theretroweb.com/motherboards/s/asus-mew-vm)
It's a very restricted board with a crappy on-board VGA and no AGP slot. Even the ISA slot is not installed though there are pins for it. It only accepts a narrow set of CPUs. I have a Celeron 500 on it.
I thought its only redeeming point is that SB-Link header it has in between PCI slots 1 and 2.. so I wanted to turn this super boring board to something more interesting...
I installed my YMF744 and connected it to the board via SB-Link. However, SETUPDS.EXE is unable to access DMA. The DMA mode option is grayed out (it's set to PC-PCI but grayed out), and of course 8-bit sound becomes disabled.
I can confirm that the physical connection is right because if I remove it, then SETUPDS will fail accessing SIRQ. I put the cable back and I don't get IRQ errors. Only the DMA error. I also tested the card on a 440BX, and it worked flawlessly there with SB-Link.
I saw the post here: Re: YMF744, DOS, no DMA? (PC/PCI, SB-link tests) that SETUPDS uses a table of recognized chipsets to enable DMA mode options. Well, I tried to mod SETUPDS to include the MEW-VM, but it didn't seem to make any difference. I've logged the PCI devices from the board (attached in the text file).. from which I identified two devices:
Device 2418h 82801AA 8xx Chipset Hub to PCI Bridge
Device 2410h 82801AA 8xx Chipset LPC Interface Bridge
The 2410 device is already in the original SETUPDS at 0xAF4B, so I only modified the byte at 0xAF83 to become 18h instead of 20h... though as I said, when run on the real board I saw no difference and DMA mode is still disabled.
I'm not sure what's the problem here... is it a software setup problem, or is the board really crappy and doesn't connect DMA lines for real?
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
