First post, by GEOCE
Hi everyone,
I recently found this old ISA card in a vintage PC lot and I’m trying to figure out what it is and how to make it work.
From the label and silkscreen:
• Typ: AT1016S
• Nr.: 02309994 (or similar)
• ATXX16 V1.0
• ATA S.C. ©1994
• 16 Analog Channels, 12 Bit, 100 kHz
• 5V, 0.7A
It has a Toshiba TMP82C55AP-2, various 74HCT logic chips, NEC and other ICs, and a big black module on top. Connector looks like DB-37 or similar on the bracket.
It seems to be a Chinese/Taiwanese OEM analog input DAQ card from the mid-90s, probably for industrial or lab use on 386/486/Pentium ISA machines.
Questions:
1. Does anyone recognize this exact model (AT1016S or ATXX16) or the manufacturer ATA S.C.?
2. Has anyone ever seen drivers, manuals or disk images for it? (DOS or Win 3.1/95 preferred)
3. What would be the best way to test it today? (port addresses, DEBUG commands, generic ISA ADC drivers, etc.)
4. Any similar cards with open-source or archived drivers that might be register-compatible?
I already tried searching archive.org, Vogons drivers section and old DAQ sites but found nothing specific. Any leads, pinouts, I/O map or even rough equivalents would be super helpful!
Thanks in advance!
