First post, by zwrr
- Member
My retro PC system is built around an SBC motherboard and includes the following components:
1. Intel 855 SBC motherboard + Pentium M 1.7G
2. GeForce 6200 PCI
3. Voodoo 2 SLI
4. SB Live
The power supply I'm using is a FLEX power supply with a 5V current rating of 15A and a 12V current rating of 28A.
The system works normally, and runs 3DMark 2001 tests for extended periods without problems, but I noticed the power supply gets very hot. I suspect this is because the system is drawing more than 15A on the 5V rail, causing the power supply to overheat ?
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
