First post, by vintageGuy81
Hello All,
Sorry if this has been covered, I looked through the threads very quickly and didn't find an exact match.
Two Biostar 1433/50UIV-A Ver 5 boards, one with an Intel 486 DX4-100 and one with an AMD 486 DX2-80.
Both have had the barrel battery removed (The one with the Intel CPU had a failed Lithium Organic battery that leaked. Doesn't seem to be bad though)
Both have had the CR2032 Holder/Resistor board soldered in place of a barrel battery, both have fresh CR2032 batteries at 3.01 or better volts.
Both will keep CMOS settings. Keeps the initial date, keeps floppy/HDD settings and other settings with the battery on board.
Both will stop the clock when powered off. After 24 hours, it has about the same time on the clock as it did when the system was powered off. This won't happen without a battery, I get the expected failed CMOS battery message.
Tried the external battery leads with a CR2032 as well, it behaves the same way. The time stops after power off.
Not sure if it's a setting, I don't remember having these issues 30 years ago. One board might have damaged runs, but the other board has had no trauma that I could observe with the naked eye.
I might try a formal cmos clear, as I read somewhere else that it could solve the problem, but it seems "silly", so I thought I'd ask here!
Any ideas would be appreciated, thanks so much for reading!
Reply 1 of 10, by 386DX40
I'd suggest you get an 'old school' 3xAA battery holder and use that instead. I've never had luck with either a single CR2032 or even a dual CR2032 holder working correctly on any of my 486 motherboards. Latest failure there was a Micronics JX30G, tried a dual CR2032 holder and the BIOS time would lose an hour a day and within a month it quit retaining settings. Switched to a 3xAA holder and everything has been perfect since. Just my two cents.......
Intel D865VP - Pentium 4 2.53 - 1GB - Geforce FX5600 256MB - SoundBlaster Live - 120GB HDD - WinME
DTK PKM-3331Y - Evergreen 5x86 120 - 32MB - WD90C31A 1MB ISA - CT2770 ISA - 30GB HDD - MS-DOS 7.10
Reply 2 of 10, by vintageGuy81
386DX40 wrote on 2026-02-14, 15:08:
I'm so glad you said that. One of my thoughts was that the voltage diff between the barrel (3.6) and the button cell (3.0) was too great, especially since the readings probably change when under load, even a load as small as what is needed to keep those settings. Thanks so much, I think I'll try a set of NiMh AAs fully charged to see if the behavior changes. If it works I can solder it onto the headers where the barrel sat and they should get a small charge as well.
Funny thing, AI suggested a cordless phone battery pack, as the voltage is closer and the design of the pack allegedly helped fight the off power shelf drain and long discharge times (like if someone didn't return it to its charging base when they finished using it).
I'll try it out and let you know. Thanks again!
Reply 3 of 10, by st31276a
I have seen boards that come with CR2032 do that when the battery starts going flat. It seems as if the RTC part needs more volts to keep ticking than what the memory part needs to retain settings. Perhaps the 3.0V is just a tad too low for those RTCs to tick.
Reply 4 of 10, by jmarsh
Just to confirm: if you go into the BIOS when the systems are on, the clock is seen running/ticking?
Reply 5 of 10, by vintageGuy81
st31276a wrote on 2026-02-14, 15:52:
That's really interesting, thanks for sharing. Over half a volt difference at nominal seems excessive to be deemed 'okay'... I'll see if I can pick up some cells locally today and run my test.
Reply 6 of 10, by vintageGuy81
jmarsh wrote on 2026-02-14, 16:23:
Yes, the clock is ticking normally. The time and date are about where they were when the power was last shut off. (i.e. I turned the second board on last night after setting the clock about 24 hours beforehand, and it still showed a few minutes past 9pm on the 13th, but was ticking normally.
Reply 7 of 10, by TheMobRules
3V is not enough for this board when using an external battery. I've had the same issue when using a CR2032 or 2xAA. Go with 3xAA or 3xAAA instead.
The onboard 3.6V barrel works fine because usually the internal battery goes through a path with a smaller voltage drop than the external header.
Reply 8 of 10, by vintageGuy81
Thanks for your input everyone! I got a set of new Energizer NiMh AA batteries and a new battery holder which read just over 4 volts after a full charge. I plugged the holder into the external battery pins and set the time. It held time overnight and is in line with my watch. That was it, the CR2032 wasn't enough.
Big relief as I thought there were bigger issues initially. You all saved the day!
Reply 9 of 10, by mockingbird
I have a question for the mavens out there... I have also experienced the same issue as the OP and performed the same fix (using a battery holder with lithium AAs instead).
But I also swapped out the UV EPROM with an EEPROM. Do ceramic UV EPROMs consume more battery?
(Decommissioned:)
Reply 10 of 10, by st31276a
The BIOS ROM should be off when the system is powered down, only the RTC chip should be powered.
