First post, by red-ray
I have got the issues down to three and am now stuck. The one I would really like to fix is the Code=15 on the ICH10 SATA controller. Does anyone know how to please?
The issue has existed ever since I first installed W98SE, that is before I installed any ICH10 or X58 .inf files.
It says there is a resource conflict in one place and then that there are no conflicts elsewhere! I tried booting into Safe Mode, deleting all the devices then rebooting and redetecting them all to no avail. I only get this issue on this ICH10 system, on my ICH9 system all is OK. I also got the issue before I patched windows when the system only had 1GB installed.
file.php?id=236348
I would also like to fix the two Code=10, but the priority is the Code=15 as I expect this is the reason SIV can't report the disk SMART information.
WMe is also installed and it has the same issues as W98. Both WXP-x64 V5.02 SP2 + W10 x64 Build 19045 22H2 with the Feb-2026 updates work well and report no conflicts.
Reply 1 of 2, by PC Hoarder Patrol
red-ray wrote on 2026-02-15, 10:45:
I have got the issues down to three and am now stuck. The one I would really like to fix is the Code=15 on the ICH10 SATA contro […]
file.php?id=236348
Not connected with this is it?... Windows 98SE on P43/ICH10, JMB368 - Here is the INF that Gemini wrote
Reply 2 of 2, by red-ray
PC Hoarder Patrol wrote on 2026-02-15, 10:58:
Thank you for you for post and it's basically the same issue. I disabled the JMicron in the BIOS, I don't need it, the system boots faster without it and it's one less thing W98 has to deal with.
I used my NoDriver Driver to make most of the issues go away, but when I use it on ICH10R SATA IDE controllers I still get the Code=15.
