First post, by Voodoo Rufus
I had the good fortune of picking up some new old stock parts over the last couple months, and want to show off the latest build.
Mainboard: BFG VNF4 Ultra
CPU: Athlon 64 4000+ 2.4GHz, San Diego core
Memory: Mushkin PC3200 Level 2 V2 Samsung TCCD memory
SSD: Samsung 860 Pro 256GB MLC
GPU: BFG 8800GT OC
Sound: X-Fi Fatal1ty
Optical: Plextor PX-760A
PSU: PC Power and Cooling Silencer 500W
Cooling: Cooler Master 80mm full copper
Case: Silverstone Fara 513
Intake fans: Dead Silence 120mm blue LED fans (goes with the blue PCB theme nicely, but not silent)
The mainboard, memory, PSU, GPU and cooler were all new and unused. Still working on getting the newest BIOS sorted out using the Chaintech files, but so far the caps seem to be fine and the VRM runs cool enough at stock speeds. I may swap the chipset cooler for my Swiftech MCX159Cu instead depending on how warm it runs when the HT speed gets increased. The only other issue I've discovered is that the SATA runs only in IDE mode and not AHCI as that seems to be reserved for later Nforce chipsets, despite being rated at SATA-2 speeds. Thankfully the Samsung SSD is fine with it. The only other thing I might do is add one of my I/O bracket mounted Lamptron fan controllers if the system makes too much noise.
I'll overclock the CPU and benchmark the system in the coming days or weeks.
Reply 1 of 5, by TheIpex
Very tasteful build, really like your choice of components. I wanted an 8800GT for my A64 system back in the day, but I had an AGP motherboard.
I'm looking at using the Fara 513 in a project, is it easy to work with/in?
Intel 486DX2 66MHz
Intel Pentium MMX 233MHz
Intel Pentium III-S 1400MHz
Reply 2 of 5, by Voodoo Rufus
Thank you. I've bought a few of these 513 cases now for retro builds. They are not very expensive, modern enough to work with, well enough built but lightweight, good airflow options, and you can fit a 280mm rad in the front easily enough if you choose to water cool. I like how it still has a 5.25" bay for an optical drive or fan controller. The only thing I don't like is that you have to pop those big old school clips to remove the front panel to install fans, but it does filter dust well enough, too.
Reply 4 of 5, by RetroPCCupboard
Nice looking build, and good cable management. I guess that, and airflow, are key advantages to these later ATX cases.
Reply 5 of 5, by FullYes
Nice, I had a SanDiego 4000+ Myself back when they were new. My first build around it was an AGP system (Abit A8V IIRC) then switched to PCI-E with an A8N-SLI Deluxe (which was a rubbish OC'er) I can remember getting 2.7GHz easily but had major issues running higher with the A8N, the Abit Board would do 3GHz with the same CPU, but it didn't lock down the PCI/AGP bus, so it was pushing reliability of the buses a bit.
Good luck and have fun o/c'ing!
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
