FIC VA-503+ schematic?
First post, by hellslinger
I'm looking for a schematic for a FIC VA-503+ rev 1.2A motherboard (Super Socket 7). I realize it's likely impossible to find, but it's worth a try. I just got a very clean board that will not beep or POST with any combination of supported CPUs, SIMMs/DIMMs, or power supplies (AT and ATX). There was a tiny bit of corrosion on the South Bridge pins, but I cleaned them off, resoldered, and verified continuity.
I recapped it and the verified the voltages on the Vcore regulator (big FET/Schotky combos) and ~3.3V regulator near the DRAM. I have another nearly identical VA-503+ that works and compared the voltages.
I tried a POST code debugger in both the ISA and PCI slot and the last code I see is 4F, which has to do with password and security for Award BIOS, I believe, but the working board shows that too.
Any suggestions or documentation someone might have would be greatly appreciated!
Reply 1 of 2, by rasz_pl
sadly no diagram for that one, here a couple era appropriate ones including pretty close MVP4 Gigabyte GA-5VMM Re: 430VX or 580VPX schematics
Since you have another one narrowing it down seems doable. Im guessing you tried swapping bios chips and cpus.
at this point in time all the magical security/passwords were still stored in regular CMOS ram, thats inside South Bridge and since
I suspect there might be more hiding somewhere, under chips, under slots, under South Bridge itself, most insidious kind is eaten VIA - looks like a black dot inside via but in reality no connectivity to the other side
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 2 of 2, by hellslinger
rasz_pl wrote on 2026-02-25, 23:36:
sadly no diagram for that one, here a couple era appropriate ones including pretty close MVP4 Gigabyte GA-5VMM Re: 430VX or 580 […]
Excellent insight and suggestion. I'll remove the south bridge and see if there's any ruined vias underneath. Thank you!
