First post, by masu
I hear no music in canon fodder
what can I do?
DOSBox 0.63
Windows XP SP2
Reply 1 of 14, by HunterZ
Please read the help request guidelines and provide a more detailed report.
Reply 2 of 14, by eL_PuSHeR
Delete SETUP.DAT and run INSTALL.EXE > Configure
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 14, by masu
it doesn't help
I selected Soundblaster Pro for Music and Sound
I hear the sound but not the intro tune.
my configuration is in my signature
using Soundblaster Live!
DOSBox 0.63
Windows XP SP2
Reply 4 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
use a very recent cvs build.
wd has recently fixed this.
Water flows down the stream
Reply 5 of 14, by masu
where can I find recent cvs builds?
current version 0.63 on my machine
DOSBox 0.63
Windows XP SP2
Reply 6 of 14, by HunterZ
Answer is in my signature...
Reply 7 of 14, by masu
thanks I will try it out 😉
DOSBox 0.63
Windows XP SP2
Reply 8 of 14, by masu
still doesn't work 🙁
DOSBox 0.63
Windows XP SP2
Reply 9 of 14, by eL_PuSHeR
masu wrote:
it doesn't help […]
it doesn't help
I used Roland MT-32 for music and SB standard for sounds. It works perfectly under DOSBox 0.63
Intel i7 5960X
8 GB DDR4 (2100)
Reply 10 of 14, by masu
strange I tries to use the same settings as you, but it doesn't work. Other games like settlers 2 works no problem
DOSBox 0.63
Windows XP SP2
Reply 11 of 14, by wd
Rank DOSBox Author
DOSBox Author
Lower the cycles, use loadfix, disable ems/xms etc.
Reply 12 of 14, by eL_PuSHeR
For me it worked without needing loadfix and I have both XMS & EMS enabled under DOSBox, too. Running with normal core - 10000 cycles under my AMD Sempron 3000+ (2GB). You will probably need to slow things down a bit for correct detection of soundcard. It did the same thing under real ms-dos if I recall correctly.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 13 of 14, by masu
what are your frameskip and core settings?
DOSBox 0.63
Windows XP SP2
Reply 14 of 14, by eL_PuSHeR
frameskip=0
core=normal
cycles=10000
Intel i7 5960X
8 GB DDR4 (2100)
