First post, by aVd
Hi, guys!
I know, that there are many people with knowledge about this type of hardware in this forum, so this is my first thread to ask for answers.
Recently I got bare Creative Sound Blaster X-Fi CT4760 sound card. I found user's manual in pdf-file on the i-net for this card, but the info I'm searching for is not there.
There is an undocumented JP3 jumper on the PCB (near the small yellow female S/PDIF jack) and I managed to trace this connections to it:
The attachment CT4760_JP3.jpg is no longer available
The S/PDIF jack is described as combined analog/digital jack in the manual, but by default it works only as digital S/PDIF connector:
The attachment manual_JP3.jpg is no longer available
There's info on this site, that there is a 5.1 speakers variant of SB Live! CT4760 card:
Several variants of CT4760 exist: Sound Blaster Live! X-Gamer, Sound Blaster Live! X-Gamer 5.1, Sound Blaster Live! Platinum and Sound Blaster Live! MP3+.
The X-Gamer 5.1 variant supports 5.1 surround sound via a combined analog / digital-out jack on the faceplate (yellow, at the very top). For analog purposes, the jack is used to provide the front centre and subwoofer channels. For digital purposes it's a compressed AC-3 S/PDIF output. The X-Gamer variant does not have this jack.
And my first question is: Will it be possible, that this JP3 jumper actually switches from S/PDIF to analog for Sub/Center in 5.1 speakers configuration?
The second question is about unpopulated JP2 jumper connected to 74F244 chip: If I move the R71 resistor to R82 missing resistor pads and solder the missing 3-pin jumper header, what this JP2 will possibly switch?
Thank you!
what comes around goes around
Reply 1 of 16, by NeoG_
On the card photo you provided, the jack only goes to a 74F244 octal buffer so it cannot provide analog audio at all. IMO JP2 and JP3 appear to be test points for the SPDIF output.
Reply 2 of 16, by aVd
Hi, @NeoG,
And thanks for your input.
NeoG_ wrote on 2026-03-01, 08:22:
This makes sense. But I didn't trace the PCB for any analog connections to this S/PDIF jack. I read a lot of search results on the i-net about these SB Live! X-Gamer and SB Live! 5.1 sound card variants and seems like there is an early variant card from the third generation SB Live! 5.1, which is using the very same PCB as Live! CT4760. Or maybe this information is not 100% correct.
The missing JP2 looks like it may be "test point", but I'm not sure. If some slight modification is done (move the R71 resistor to R82 missing resistor pads) it may switch the "yellow line" output of the 74F244 (3-state output buffer):
The attachment JP2.jpg is no longer available
For JP3 jumper header there are two variants to install jumpers.
This one seems more reasonable (deactivating the "yellow" output from 74F244 by connecting it to ground and connecting "red" outputs from 74F244 to S/PDIF jack):
The attachment JP3_variant_1.jpg is no longer available
And in the second variant (I see not much of a reason to connect "red" and "yellow" outputs from 74F244):
The attachment JP3_variant_2.jpg is no longer available
Reply 3 of 16, by NeoG_
aVd wrote on 2026-03-02, 05:13:
I think the information is correct, however the 6 channel capability for the CT4760 is digital only as it does not have the additional DAC channels to power the analog outputs. I found an article which outlines the whole process of adding 5.1 support to a CT4670 and it requires the digital DIN extension bracket and is designed to interface with Creative/Cambridge branded speakers that can accept the digital DIN connector.
http://ixbtlabs.com/articles/livetolive51/index.html
As pointed out in the article, it is possible to provide your own center/sub analog output by decoding the SPDIF signal from the digital extension header using your own decoder, the article writer used a second sound card to perform the decoding. I supposed it would be possible to do it all onboard by isolating the digital jack and using a small SPDIF decoder circuit between the digital extension header and the now isolated digital jack. Isolating the jack would be done by removing all JP3 jumpers and removing R71. That would allow you to feed Left, Right and Ground into the JP3 header pins from the decoder circuit.
That would be in addition to modifying the EEPROM to allow the use of the 5.1 liveware drivers of course, if the card does not already have a 5.1 enabled eeprom code.
Also it makes clear why there are two independent SPDIF lines to the digital jack in the PCB design, it supports two stereo SPDIF streams using a stereo minijack plug for 4 channel digital
Reply 4 of 16, by ott
NeoG_ wrote on 2026-03-02, 09:39:
Something doesn't add up here or CT4670 really does have 6-channel version (5.1).
I noticed that this CT4760 (in the photo from RetroWeb) has 2ch DAC Philips UDA1330A in addition to main 4ch AC'97 codec (Sigmatel STAC9721T).
This combination (or similar Philips/Sigmatel chips) can be found on other Live! 5.1 cards.
I also heard that UDA1330A had better sound quality than Sigmatel, and it was popular to use the rear outputs.
Reply 5 of 16, by NeoG_
ott wrote on 2026-03-02, 11:45:
Something doesn't add up here or CT4670 really does have 6-channel version (5.1). […]
I think it is used for some other purpose because all versions of the Live card have this additional philips stereo I2S DAC as well as the sigmatel codec, both G1/G2 4 channel and G2/G3 6 channel live cards
Edit: So it seems like the story is that the G1/G2 cards have a stereo AC97 codec (STAC9721/CT1297) plus the additional stereo I2S DAC for a total of 4 analog output channels, and the G3 cards have a 4 channel AC97 codec (STAC9708) plus the additional stereo I2S DAC for a total of 6 analog output channels.
Reply 6 of 16, by aVd
I think the information is correct, however the 6 channel capability for the CT4760 is digital only as it does not have the addi […]
Yeah, I know about this article with EEPROM model ID modification and that's the reason I started to search for info on Live! X-Gamer 5.1 CT4760 or will it be possible to modify the standard Live! X-Gamer card in such way, so there will be no need of the additional connections to second sound card used solely as digital to analog convertor. There's also similar article in Russian language here. Seems like the undocumented jumpers JP3 or JP2 may be used for connection to Digital-In on the second sound card.
I'm wondering if SB Live! X-Gamer 5.1 sound card really do exist, and if so what will be it's model ID stored in the EEPROM.
Reply 7 of 16, by aVd
Hi, @ott,
And thanks for this info. My SB Live! CT4760 sound card has both Sigmatel STAC9721T and Philips UDA1330A chips just like the one on TRW's picture. And that's why I used the same picture for my drawings on JP2 and JP3 connections. But the card from the link is still the standard Live! X-Gamer (non-5.1), right?
Reply 8 of 16, by NeoG_
Actually I just reviewed the information on the DOSDays site and it says the CT4760 "X-Gamer 5.1" has 6 channel analog output, but it's not possible based on the PCB design so I think the information is not correct. I also emailed the site owner recently about an incorrect piece of information on the CT1770. I assumed the "5.1" version referred to was digital output only, but if it claims to have 6 channel analog I don't think it exists.
Reply 9 of 16, by aVd
NeoG_ wrote on 2026-03-02, 11:59:
Thank you, @NeoG! This explains everything except the purpose of the JP2 and JP3 jumpers 😀
I'll consider the SB Live! X-Gamer 5.1 and the SB Live! 5.1 with PCB from CT4760 models as non-existing or never released models. And now I see no point to modify my 4-channel CT4760 to 5+1 channel SB0060 as it will need connection to additional sound card for the sub/center channels output.
Reply 10 of 16, by aVd
NeoG_ wrote on 2026-03-02, 13:17:
Yep, seems like the current info for SB CT4760 models on dosdays site is not 100% correct. This site contains a lot of useful info and resources about retro hardware, so I hope the author will correct the things according to your notes.
... JP2 and JP3 jumper headers on CT4760 will remain a mystery.
Reply 11 of 16, by aVd
Why? Why I opened those Sigmatel STAC97xx datasheets?! 🤣
Now I'm totally confused.
This is the pinout of Sigmatel STAC9721 "Stereo AC'97 Codec With Multi-Codec Option", which is on my Live! X-Gamer CT4760 card:
The attachment STAC9721_pinout.jpg is no longer available
And this is the pinout of Sigmatel STAC9708 "Multi-Channel AC'97 Codec With Multi-Codec Option", which is on Live! 5.1 cards like SB0100 and SB0220:
The attachment STAC9708_pinout.jpg is no longer available
And all of the pins and analog outputs match except in the names of LNLVL_OUT_L/R on STAC9721 and DAC_OUT_L/R on STAC9708 (legs 39 and 41 are for analog output signals on both chips).
After all Live! X-Gamer CT4760 cards with Sigmatel STAC9721T and Philips UDA1330A chips seem capable for 6-channel analog audio. What do you think, guys?
Reply 12 of 16, by NeoG_
aVd wrote on 2026-03-02, 14:47:
You are conflating multi-codec and multi-channel
It clearly states in the documentation two sigmatel chips are required to exceed a single chips output channel capacity in a multi-codec configuration.
The STAC9721T only has two onboard DACs
Reply 13 of 16, by aVd
NeoG_ wrote on 2026-03-02, 21:34:
My confusion is due to lack of detailed descriptions for LNLVL_OUT_L/R (STAC9721) and DAC_OUT_L/R (STAC9708) analog outputs. I didn't expect to see more analog outputs on STAC9721 legs 39 and 41.
Reply 14 of 16, by NeoG_
aVd wrote on 2026-03-03, 03:48:
LNLVL_OUT is a copy of the stereo mixer output, Sigmatel says it's a "true line-level out for headphones or speaker amplifiers". I guess that means it has a different impedance or drive capability than the standard line out. You can see in the STAC9271 mixer functional diagram that the two sets of outputs are ganged together. On the STAC9708 line out is independent from dac out.
Reply 15 of 16, by aVd
NeoG_ wrote on 2026-03-03, 04:02:
While using search function in both pdf-files I missed these mixer functional diagrams. Now everything is clear. Thanks!
Reply 16 of 16, by ott
Thanks for correcting me!
Indeed, the SB Live (CT4760) only has 4 analog outputs: STAC9721 (2ch DAC) + UDA1330 (2ch DAC).
The SB Live! 5.1 (SB0100/SB0220) has different set: STAC9708 (4ch DAC) + UDA1334 (2ch DAC).
