First post, by acl
Hello
A few years ago, I got a 286 system through a local collector I used to trade with.
I knew nothing about this system, and the owner only told me that it powered on, displayed the POST, and that the power supply was making strange noises.
The deal was concluded: the unknown 286 system in exchange for a matching pair of 6600 GTs for an SLI he wanted to set up.
I put the 286 on the back seat of my car, we shook hands, and this is how it started.
The attachment IMG_20250316_164553-red.jpeg is no longer available
The attachment IMG_20250316_164608-red.jpeg is no longer available
The system stayed a few months in my garage before I had the time to have a look.
With the power supply being in a worrying state, I just opened the case to see what the system was made of. What I found:
  • Interesting design for an AT system. Surprisingly integrated
    • Daughterboard with the CPU and RAM
    • Backplane with integrated serial, parallel port, EGA display adapter, mouse/joystick port, and floppy controller
  • WD "Winchester" card
  • Paradise PVGA1A 8bit ISA VGA card
  • One floppy drive
  • One hard drive
I also found more info online about this system. It's a Schneider Tower AT 201.
The system seems to have been upgraded at some point, as the VGA card was not part of the initial setup. I suspect that the hard drive and hard drive controller were not part of the initial system either.
Based on the information found online and what I've seen inside the case, I already had some worries:
  • Non-standard power supply
  • Non-standard floppy drive
  • Dallas chip probably dead
Since the previous owner told me that the system could power up, I took the risk and powered it up.
The attachment IMG_20251109_102308-red.jpeg is no longer available
Ok, it runs. But after a few minutes, the power supply started to make unusual noises, and I shut the system off to prevent any damage.
What I learned:
  • The system powers up
  • The system responds to the keyboard and I can access the BIOS config
  • The power supply is not reliable
  • The floppy drive seems to work
  • The system can't boot from the disk; the type is not correctly set in the config or there's nothing on the disk
My first step will be to fix the power supply.
As mentioned before, this system was really integrated and almost looked like a newer system. With integrated peripherals... and a front panel push switch to power on the system.
The article on oldcrap.org linked above explained a bit what made the original power supply "non-standard". More importantly, the author made the service manual available, with the connector pinout described (see below).
  • Physical interface (connector): neither AT nor ATX.
  • The white cable is the power-on switch. It is apparently held down by the motherboard when the power switch is activated on the front panel.
  • The brown cable is the Power Good signal. It tells the motherboard that the power supply is delivering power.
Pinout:
The attachment Capture d’écran du 2026-03-07 22-15-18.png is no longer available
With this information, I thought it would be easier to adapt an ATX PSU. They are easier to find, cheaper, more recent.
But in any case, I would have to cut the wires from the original PSU and solder them elsewhere.
Instead of modding a PSU, I thought it would add flexibility to build an adapter to be able to plug any ATX PSU into this system. So I went that way, repurposing an ATX extension cable.
The attachment IMG_20260222_225455-red.jpeg is no longer available
For the PSU itself, I picked an ATX unit that I knew to be working properly and that was able to provide the -5V (newer ATX units generally don't). So, a retro PSU, but not antique.
I cleaned it thoroughly, and I had to drill holes in the PSU cover to align with the mounting holes of the case.
I quickly plugged in the system, and it started on the first attempt.
The only weird thing is that the power-on LED does not light up. I can't remember if it worked initially. I will have to check that later.
Now that there are fewer risks of damaging the system with a faulty power supply, I can move to the next item in the checklist: ensuring that the system can boot an OS.
Reply 1 of 12, by acl
When I started the system for the first time, I could hear the floppy drive seek at startup. This was the sign that the BIOS was at least able to detect it and command it.
I prepared a set of MS-DOS 5.0 install floppy disks and gave it a try.
The system booted! Awesome!
The MS-DOS installer asked me where to install the OS, but no hard drive was available.
OK, that's fair—I didn't even configure it in the BIOS. Let's have a look.
After a reboot, I accessed the BIOS and looked at the supported disk drives. Unfortunately, mine was not detected.
The geometry was not written on the disk label, and I didn't even know if it was working at all.
I tried several other disks that I knew to be working, with no luck.
CompactFlash adapter? No luck either.
I quickly realized that hard drive support would be something painful to tackle. I don't keep a lot of old IDE drives, and most of them were from the mid-90s and not supported by the BIOS.
I started to look at the XT IDE project (https://xtideuniversalbios.org/).
XT IDE is well known here on Vogons. It's a piece of software that aims to bring support for "modern" hard drives to systems as old as XTs. It is generally loaded as an option ROM and allows disks unsupported by the motherboard BIOS to be recognized. Like a RAID card that makes a disk array appear as a single disk and allows booting from it, XT IDE detects and supports modern disks and allows an old system to boot from them.
Using XT IDE requires a way to load the option ROM during boot. Looking online, there are several ways to achieve that—from dedicated cards (you need to build or buy one) to network card boot ROMs. Having several ISA network cards, I wanted to do it that way.
The network card itself is not enough. Of course, you need an E(E)PROM to put in the socket and a way to program this E(E)PROM. Fortunately, I have a box full of old E(E)PROMs.
With the help of (this topic), I knew that I needed a 16 KB ROM to store the "full" binary of XT IDE (there are versions requiring less ROM space, but with fewer features). I found several EPROMs of this type, but none of them were EEPROMs. So my ROM programmer would not be able to erase them. I needed to use a UV eraser.
I ordered a UV eraser from Amazon and a XGecu T48 programmer. In the meantime, I configured the ISA network card.
The attachment 1772918404176-red.jpeg is no longer available
The card I used is a D-Link DE-220PT. It is a network card without jumpers that requires configuration from a DOS-based utility. I installed the card in another system and used the driver found on TheRetroWeb (https://theretroweb.com/expansioncards/s/d-link-de-220pt).
The attachment IMG_20260222_225438-red.jpeg is no longer available
The settings are saved on the card in a dedicated EEPROM.
The attachment IMG_20260218_221733-red.jpeg is no longer available
I received the EPROM UV eraser and the programmer a few days later. After erasing the EPROMs, the T48 was able to burn the XT IDE image. But I was unaware that the XT IDE image needed to be configured first. The XT IDE option ROM could not start. Exactly the same thing happened to the YouTuber Bits und Bolts in this video: https://www.youtube.com/watch?v=lnb6zamDI6A
This is very important: you MUST configure the XT IDE ROM with the utility, writing the settings in the image file, and ONLY AFTER this step, burn the ROM.
I used the 'atl' (AT Large?) image and left almost everything with the default values, except the number of IDE controllers (set to one instead of two).
I wrote the image on a new EPROM and it was able to detect my CompactFlash card.
Awesome!
The attachment 1772926295668-red.jpeg is no longer available
In the BIOS, I disabled both disks and left them to be handled by XT IDE.
The next step would be to try to install MS-DOS 5.0 from the floppy drive to the disk.
After inserting the MS-DOS 5.0 floppy disk #1 in the floppy drive, I pushed the reset button. No drives visible in the POST, as expected since I left the HDD configuration empty in the motherboard BIOS. Shortly after, I saw the XT IDE message, detecting my CompactFlash card. I hit F2 for the XT IDE boot menu and I selected the floppy drive. The MS-DOS 5.0 installer started… but I was unable to select "hard disk installation". I was stuck instead with "install to other floppy".
I had an intuition and pressed reset again to access the motherboard BIOS. I added a random disk configuration in the motherboard and retried the operation. Reset again—disk not detected by the motherboard. No problem. F1, continue. On the XT IDE option ROM screen, I pressed F2 for the boot menu, booted from the disk, and back to the installer. The "hard disk installation" option was available. MS-DOS 5.0 was installing correctly and was able to boot to the hard drive (CompactFlash).
After the installation, I went back to the motherboard BIOS, cleared the hard drive configuration, pressed reset again, and had no problem booting to the DOS system. Apparently, the issue was only with the MS-DOS disk detection routine.
But pressing reset all the time was just a workaround to avoid turning off the system entirely. I avoided that because the BIOS settings would vanish as soon as the power would be turned off because of the Dallas chip battery being dead. Even by pressing the reset button, the motherboard still complained that something was wrong with a beep, and I had to press F1 to continue every time. Fixing this would be my next step for this restoration.
Reply 2 of 12, by acl
Dallas chips are well known among retro PC users for always being dead and needing replacement. Fortunately, it's well documented and easy to do.
I followed this documentation: https://8bitclub.com/2025/07/28/modifying-a-d … cr2032-battery/
I've read that some also cut the connections to the old battery to avoid the new CR2032 being drained by the old empty battery. I chose not to cut the connections. Maybe I'm wrong. If the battery is drained too quickly, I will try that, but I just soldered wires on the internal connectors after exposing them with a metal file.
The attachment IMG_20260222_104117-red.jpeg is no longer available
The attachment IMG_20260222_105835-red.jpeg is no longer available
The attachment IMG_20260222_111420-red.jpeg is no longer available
The attachment IMG_20260222_111930-red.jpeg is no longer available
I applied hot glue on the connector solder points to protect them and under the coin cell battery holder (scavenged from a dead motherboard).
I placed the Dallas back in the CPU board inside the system and powered it on. I configured everything properly in the motherboard BIOS, saved, then powered it off. I waited a few seconds and powered it back on. And everything worked properly. The date was maintained (funny to see 2026 on this system), no error beep, no F1 to press—the system booted to DOS without any human interaction. Great!
Until now, I mainly used the system outside of its case. Now that it's working, the next step will be to install it back in the case, but not before a thorough cleaning.
I used soap, a brush, a sponge, and hot water to clean it. After letting it dry for a while, I used a "magic eraser" for small scratches and to make it a little bit brighter. I also cleaned the cables, the boards, the metal parts, and the PSU (with a soft brush and alcohol when required). The case looked really great after this cleaning.
Manipulating the case gave me an idea. The system came with only one floppy drive, but there are two floppy drive slots. One will be empty. I could use some black tape to seal it and make it look like it had two drives. Or… I could integrate the CompactFlash card reader in the empty floppy slot. I really wanted to explore that idea. I knew what to do next.
Reply 3 of 12, by acl
The CompactFlash to IDE reader I have is one that can be mounted on an expansion slot to the back of the case. See picture.
The attachment Capture d’écran du 2026-03-07 22-23-35.png is no longer available
What I found interesting was that I had two screw holes to attach it to the bracket. But these holes could also be used to mount the card reader flat on a surface. I removed the bracket and mounted the card reader on a piece of wood of the correct size: the width of a floppy drive. With proper measurements, I was able to align the card reader correctly with the floppy drive hole on the case.
The attachment IMG_20260222_221405-red.jpeg is no longer available
The attachment IMG_20260222_223322-red.jpeg is no longer available
I added black tape to the side to hide that the card reader does not take the full width of the hole. I also filled the ejection button hole with masking tape to make it look like a real button (almost). And the result looks OK to me.
The attachment IMG_20260222_223327-red.jpeg is no longer available
The attachment IMG_20260223_002639-red.jpeg is no longer available
There is one little drawback: the activity LED on the card reader is not visible and the activity LED on the case is not connected. That's something for later.
So at that point, the list of modifications was:
  • New power supply
  • XT IDE on a network card
  • Modded Dallas chip
  • Cleaned case
  • Integrated CF reader in a floppy drive bay
  • MS-DOS 5.0 installed
Reply 4 of 12, by acl
The system is usable and I used it a little while for tests.
I installed SimCity and The Secret Of Monkey Island to try it.
Two things were quite frustrating when using the system:
  • No mouse
  • PC Speaker sound
No mouse? Well, not exactly. I tried a serial mouse on the motherboard serial port and it worked (I'm using the CuteMouse driver https://cutemouse.sourceforge.net/), but the motherboard also provides a "mouse/joystick" connector which takes the physical form of a serial port. There is also a configuration option in the motherboard BIOS—"mouse/joystick"—with valid options being "Mouse," "Joystick," and "Disabled."
No luck with my serial mouse with CuteMouse on this port. The mouse worked properly on the regular serial port, but since this was the only available port, this was quite limiting for the system. This would have prevented the use of anything on the serial port along with a mouse.
I suspected this port to be a variant of a BusMouse port: https://en.wikipedia.org/wiki/Bus_mouse
Once again, the service manual came to the rescue with the schematics. It was obvious that the port was not connected to the same controller as the serial port. And the pin names of this mouse port matched the ones found on a BusMouse device: XA, XB, YA, YB, BR, BH, BL.
The attachment Capture d’écran du 2026-03-07 22-16-53.png is no longer available
Using my regular mouse is not possible and there was another issue: this mouse connector was not soldered to the motherboard but attached to the old PSU with rivets, which I had replaced with a new one. Of course, there was the option to move it to a bracket, but I found a better option: replacing the "Winchester" disk card with a more integrated "Super IO" card, sporting IDE like the Winchester card but serial and parallel as well (optionally floppy and joystick ports). Fortunately, I had plenty of these around and I installed one in the system.
For the settings, I enabled COM2, LPT2, and IDE, while disabling COM3, the floppy controller, and the joystick port. Everything is configured through jumpers on the card, with the reference printed on the back of the PCB.
The attachment IMG_20260222_225155-red.jpeg is no longer available
The attachment 1772920628985-red.jpeg is no longer available
The "Super IO" card was detected by XT IDE without any issue and booted to DOS. From the system, I was able to use the mouse on both serial ports: the one from the motherboard and the one on the "Super IO". I added black tape to cover the hole in the case for the BusMouse port. Adding it back is still possible—the connector headers are on the motherboard—but I think that having two serial ports is more flexible than a BusMouse port.
And for the joystick port, well, the next step is to add a sound card, so there will be one soon.
Reply 5 of 12, by acl
To be clear, no, having a sound card on a 286 is not very period correct. But the same goes for a network card (with XT IDE, but the network card is still usable), or a CompactFlash reader. A Super IO is period correct, but not the one I installed. I'm definitely in the process of making this 286 flexible and usable like a modern system and not performing a strict restoration. But nothing irreversible (except the PSU, which was dead anyway).
I thought about using a homemade Covox Speech Thing as a sound device (https://en.wikipedia.org/wiki/Covox_Speech_Thing). But there are not a lot of supported games, and installing a proper sound card would be better.
Regarding period-ish correct sound cards, I have two options available: a Mediavision Thunderboard and a SoundBlaster Pro 2… I chose to use none of them, as they are part of my collection and I don't really want to use them permanently on a system for now. So I looked for another sound card that could be used with SoundBlaster Pro compatibility, not plug and play, and preferably no TSR program. I found an ES688 AudioDrive, a 1994 card, SB Pro compatible and with an OPL3 chip (a 1:1 copy on my board).
The attachment IMG_20260225_011341-red.jpeg is no longer available
Configuring the sound card was not easy. The driver was a driver pack aimed to support multiple ESS sound cards: ES688 Audiodrive Full install for DOS on this page (https://www.vogonsdrivers.com/index.php?catid … menustate=63,53). Some of the supported cards being plug and play required configuration through a utility. The installer insisted on having the driver loaded by config.sys, and this prevented the system from starting.
With trial and error, I finally found that the driver in config.sys was not needed at all. But an initialization program was required, but not for all arguments—only IRQ and DMA. Changing the base address through the utility would freeze the system. So here is my setup:
  • Jumpers on the card set to DMA 220, IRQ 5, DMA 1 (IRQ7 already used by LPT1)
  • Driver pack installed
  • Line from config.sys removed
  • Custom config in autoexec.bat
autoexec.bat
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
MODE CON CODEPAGE PREPARE=((850) C:\DOS\EGA.CPI)
MODE CON CODEPAGE SELECT=850
KEYB FR,,C:\DOS\KEYBOARD.SYS
C:\ESSUTIL\ESSCFG.EXE /V:1 /I:5 /D:1
C:\ESSUTIL\ESSVOL.EXE /V:8 /L:8 /W:8 /M:0 /C:8 /S:8
C:\DOS\CTM.EXE
SET BLASTER=A220 I5 D1 T2
config.sys
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\SETVER.EXE
DOS=HIGH
COUNTRY=033,850,C:\DOS\COUNTRY.SYS
DEVICE=C:\DOS\DISPLAY.SYS CON=(EGA,,1)
FILES=10
After this configuration, the sound worked well with both digital and FM synth in games such as Wolfenstein 3D, The Secret of Monkey Island, and Dune.
The system is almost ready but there are still some very small details to fix, like the front panel LED. Let's work on that.
Reply 6 of 12, by acl
I vaguely remembered that when I used the system for the first time, the front led worked. At least for the floppy drive and the power status. Also, the first time I disassembled the system I found a two-pin connector attached to the HDD. I was pretty sure that this two-pin connector was the HDD activity LED.
When I configured the "Super IO" board I read the jumper settings printed on the back and it mentioned the HDD activity LED. I opened the system, unplugged the card and yes, there is an HDD activity LED connector on "J2"
The attachment 1772920870813-red.jpeg is no longer available
The attachment 1772926295715-red.jpeg is no longer available
After connecting the two pins, I powered up the system and the LED started to blink. Great! but the power LED was still off. I started to suspect something and I had to check with a multimeter.
The attachment 1772926295742-red.jpeg is no longer available
5V—that's a lot for a small red LED. I'm not sure how much this LED can take, but it's burnt. Looking at the schematics it seems like the LED receives the "power good" signal. On an ATX motherboard it is 5V and from what I read in the service manual, it was 5V as well with the original PSU. I replaced the original LED by a new one, with a 200-ohm resistor.
The attachment 1772926295726-red.jpeg is no longer available
I placed the LED/switch panel back in the case and powered up the system. Voilà! We have a working power LED. This was, for now, the last touch to this system.
The attachment 1772926295705-red.jpeg is no longer available
Reply 7 of 12, by acl
As of now, everything works well and the system is very pleasant to use. Loading files/games is super easy through the CompactFlash card and having a sound card and a mouse really makes the system interesting to use.
Final pictures :
The attachment 1772926295693-red.jpeg is no longer available
The attachment IMG_20260223_002549-red.jpeg is no longer available
The attachment IMG_20260223_002607-red.jpeg is no longer available
The attachment IMG_20260223_002806-red.jpeg is no longer available
Reply 11 of 12, by citronalco
If the floppy drive was a 1,44 MByte one:
Could you please write what manufacturer & type it is?
Reply 12 of 12, by acl
Paadam wrote on 2026-04-09, 18:58:
Very nice system!
Thank you very much.
I'm planning a Windows installation for the next step. And maybe try to plug a 5.25 inch floppy drive to the external floppy connector (unfortunately i don't have the original unit)
citronalco wrote on 2026-04-10, 10:29:
It's a Toshiba 720K drive (Toshiba ND-352SH-A)
I don't have a picture of it but it's the same as the one depicted here : https://oldcrap.org/2021/03/14/schneider-tower-at-201/
