First post, by dylanfm
I'm trying to fix an old Model 25 and I'm getting a 301 keyboard error and press F1 to continue while booting. I'0ve tried the 2 keyboards I have that have a PS2 type connector and both give the same error. I also checked the fuse next to the keyboard connector and it is good. Is there something special about the keyboard I need? Is a common error? Any ideas about what I should do to fix this?
Full history as I know it (since I only got this computer yesterday):
When I got it, there was a burnt up cap taped to the top of the case. When I tried to turn it on the first time, the power light would come on for a second and then turn off. When I inspected the board I found that several of the caps have already been replaced. Eventually I found that cap on the -12V rail was shorted. Since I don't have a replacement and I wanted to see if that was the problem, I just cut it out. I also noticed that another capacitor on the +12V rail had been cut out and was missing (presumably the one taped to the outside of the case). After that, when I powered it up the floppy drive let a lot of smoke out. I read somewhere that these floppy drives are prone to needing all the caps replaced. So I removed the floppy drive. Now when I power it up I get a floppy drive error and then the keyboard error I mentioned above. I don't think not having those 2 bypass caps on the +12V and -12V rails would cause the keyboard not to work, but maybe...
Dylan
